Tranny help
Discussion in '4Runners' started by chastain90, Aug 19, 2012.
  1. chastain90
    chastain90 [OP] Well-Known Member
    Zach
    North Georgia
    07 Tacoma TRD Off Road
    Got a friend with a 4runner and the transmission went out you can put it in any gear and it just revs has anybody had this problem
  2. Bawlzdeep
    Bawlzdeep I'm dropping the hammer
    Jon
    Penn Valley CA
    S/C'd 97 4Runner 5spd
    lift, tires, winch, 5spd swap, dual lockers..
    Hope the shift linkage came off! Otherwise he's looking at a possible rebuild. Take a look at the linkage that goes into the trans under the truck, run it through the gears with someone watching. Check fluid level, color and smell. If the clutches are gone then there will be a lot of black/gray silt in the fluid. Might need a filter change.
    This is all assuming it's automatic. Otherwise it's just a smoked clutch. Way cheaper than an auto rebuild!
    Good luck
