Tranny help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bosbo6939, Feb 21, 2021.
  1. Feb 21, 2021 at 10:26 AM
    bosbo6939
    bosbo6939 [OP] Member
    WA
    08 dbl cab TRD or
    So a few years ago my truck, 2008 double cab trd or with auto, suffered from torque converter shudder. I had a shop do a tranny flush and it did not help. At the time it was suggested I put in dr tranny shudder fix as a last ditch effort. I did this and the shudder went away within a mile but ever since the tranny has had a whine and every now and again shifts funny. I’ve grown tired of it sounding this way and am looking at gearing the truck and locking the front but I want to get the tranny dialed first. I’ve been told to just drive it till it breaks but I’m not a fan of that.
    I’m really hoping that someone has experience in this and has either a solution or can point me in the right direction for getting a new tranny. I’d love to have the 6spd but prob more work than it’s worth. I have found used a750f trannys on CL for $500ish but usually not the right year and am not sure of the actual difference. Should I just bite the bullet and drop the cash for a reman? Thanks.
  2. Feb 21, 2021 at 9:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you read through this thread about 2nd gen autos?
    TnShooter likes this.
  3. Feb 22, 2021 at 4:08 AM
    GP_spence
    GP_spence Well-Known Member
    AL
    2013 DCSB TRD Off-Road 4x4
    Can you verify that the shop did the proper level check procedure? These transmissions act funny if the fluid level isn't dead on.
    If you aren't sure I'd recommend doing that first. How many miles on the truck when you did the flush? And was it the first time the tranny had been serviced?
  4. Feb 22, 2021 at 5:29 AM
    bosbo6939
    WA
    08 dbl cab TRD or
    I read through a bunch and was getting overwhelmed. I’m going to guess it was around 150k. I believe it was the first service. I’m not sure the level check was done properly. The shop was kinda a joke. I had to add the additive myself and the level seemed fine when I did that. The truck now has 168k. No longer a daily driver.
    GP_spence likes this.
  5. Feb 22, 2021 at 5:33 AM
    GP_spence
    AL
    Ricardo13x likes this.
  6. Jul 18, 2022 at 8:10 PM
    bosbo6939
    WA
    08 dbl cab TRD or
    Only a year and a half later I finally changed the tranny filter and fluid. Made sure to use genuine Toyota and it now acts like a brand new truck.
    Leomania and Ricardo13x like this.
  7. Jul 18, 2022 at 8:44 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The cheap shop is the expensive shop
  8. Jul 18, 2022 at 8:49 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Good job!
  9. Jul 18, 2022 at 9:12 PM
    bosbo6939
    WA
    08 dbl cab TRD or
    I think my saving grace is I just don’t drive the truck very often. Prob put 3k or less a year in it. Seems to be fine. I’ll drive it a bit then drain and fill. Think my next step will be gears now.
    Steves104x4 likes this.
