Tranny is shifting hard...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Nov 28, 2010.
  1. Nov 28, 2010 at 6:45 PM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    97 Tacoma 4cyl 5 speed. I have the gear lube in the tranny that the truck calls for and on cold morning (sub 40) the tranny is very hard to shift. once it all warms up it shifts fine.
    What I am wondering is if anyone else is having this problem and IF switching to synthetic would help the issue? I was thinking about trying some Royal Purple in it and see if it help, but I don't wanna wast $60+ if it does not make it shift better cold.
    Any thoughts???
  2. Nov 28, 2010 at 8:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Is it all gears? Or mostly 1st to 2nd and downshifting to 1st?
    A synthetic will help a lot, especially with temp issues. In my old '98, putting in Redline synthetic made a huge diff. I used MTL, its specifically designed for trannys, no friction modifiers.
  3. Nov 29, 2010 at 5:25 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Its hard to put into 1st period, 2nd is hard, 3rd is even a little hard. Downshifting into 1st when it is cold is just about impossible.
    So it might be worth a try then...
