Tranny issues on 6sp manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by southerntaco171, Jun 27, 2012.
  1. Jun 28, 2012 at 3:39 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    The "hopping" sounds to me like the clutch glazed. A lot of the time if a clutch glazes over you can correct it with a hard slip or two. Not enough to overheat the flywheel, but enough to expose a bit of new surface.
    My last Honda's stock clutch was terrible for that. The more conservatively the car was driven, the more it would shudder on takeoff. I finally got to the point that I'd run some twisties to wear it a bit and the problem would go away for a couple months.
    My 6spd clutch does it too, but far less frequently.
    If this is the OP's situation, it usually gets much worse on humid mornings or in the rain, and when the clutch is still cool.
    Back in the old old days the owners manual would say put the front bumper against a tree and smoke the clutch.... don't do that though.
  2. Jun 28, 2012 at 3:44 PM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    had this same issue right after I replaced my clutch around this same time last year, replaced the TO bearing and it went away for a few weeks. Chirp came back and now its worst then ever, really considering that URD sleeve kit to get rid of this annoying chirp/squeek
  3. Jun 28, 2012 at 5:46 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    With a manual, shifting is left up to the driver, just how I like it. No wonder you were disappointed.:D
    The redesign and matching TSB happened around march 2011 IIRC, between the time I ordered my URD kit and when I received it. Then I priced the parts from the dealer, and was happy to continue installing the URD kit. IIRC, new production from then on also had the update, but don't quote me on that.
  4. Jun 28, 2012 at 6:52 PM
    iroh
    michigander
    tonneau
    I must have a high tolerance for smoothness. I spent a lot of miles in a Jeep YJ when I was very young and the 1-2 shift throw on that beast had to be about a foot. 123 hp, 15 mpg, no AC, one speaker worked... It finally lost enough compression to not go highway speed at about 190,000 miles.
    I was hoping the TSB was before Mar 2011... Toyota shows my new TOB going in dec 2010. They labeled it "installed SOP bearing" after throwout bearing diagnosis and R&R description... no idea what that means.
  5. Jun 28, 2012 at 8:05 PM
    southerntaco171
    southerntaco171 [OP] Well-Known Member
    Ocean Springs, MS
    2017 TRDOR
    2013 regular cab 4x4 Bilsteins Spc uca Eibach coils 285/75/r16 Projector retro 5500k hids 2017 TRDOR DC Weathertech Floor mats 5500k Morimotto Headlights and Fog lights 5% Tint 2008 Toyota Tacoma(SOLD) 8k Hid Headlights and fog lights, BHLM, 6" Pro Comp basic, 2.5" top spacer, Allpro front bumper, Jvc KVX10 double din, 2 crossfire bmf 12's, Memphis 6x9s, cherry bomb exhaust, K&N drop in intake,
    The way you described the way your Honda drove is exactly how my truck feels.
    I ordered to URD TO bearing kit today and I intend on leaving it up to the mechanic to decide if anything else needs to be replaced. Ill keep everyone posted.
  6. Jun 28, 2012 at 8:25 PM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    it's still not a shitty transmission. And I had an automatic Tacoma. Couldn't stand the gear hunting. The bump on take off or stopping. The cruise control panic rev to maintain speed on a hill. Also how boring are automatics? So different strokes for different folks. I will fix it if it breaks. It's a machine. They break and none of them are perfect.
  7. Jun 28, 2012 at 11:08 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    This whole thread and all the others make me thankful I went with the 2.7/5 speed setup. I've got horsepower when I need it! (Every other vehicle I own has a V8) So having a 4 banger does not bother me at all, they do have decent power too and are fun to drive.
  8. Jun 29, 2012 at 7:39 AM
    Wallygater
    USA
    You can't get a dbl cab with the 2.7 so I buy the v6's. Don't look into that much man. The 6 speed is fine.
  9. Jun 29, 2012 at 8:01 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I thought you could get a double cab with the 2.7 starting in 2011? Not sure if its auto or manual though.
  10. Jun 29, 2012 at 8:03 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    just checked. I can configure a 2012 dc prerunner with 2.7 auto. can't do manual with the dc or as a 4wd. Might be different in other regions.
  11. Jun 29, 2012 at 9:26 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This. And the correct way to fix this is a new clutch and if there is enough material on the flywheel get it refaced. If not replace the flywheel, clutch, pressure plate and throwout bearing.
  12. Jul 14, 2012 at 9:32 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Mine just started making the chirping sound a couple of days ago..It goes away when the clutch is depressed.I am going to the dealer on monday. I have a 2009 V6 with 6 speed..27,000 miles
  13. Jul 14, 2012 at 9:41 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    warranted... your golden
    Just another experience - I'm just over 100K on a stock clutch and did not get "the squeak" until about 10K ago.
    I'll eventually go the URD Route and upgrade the clutch at the same time.
    :cool:
  14. Jul 15, 2012 at 5:01 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Automatics are for people that can't drive a stick. The manual does not shift it's self you do if it does not shift smoothly kinda points to the one driving it.
  15. Jul 17, 2012 at 10:55 AM
    #35
    roadking1
    n.j.
    The dealer took my truck in right away and ordered the parts.He was aware of the TSB..I will have it back tommorrow.repaired under the power train warranty.
  16. Jul 17, 2012 at 1:11 PM
    #36
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :thumbsup:
    Good to hear! :D
  17. Jul 17, 2012 at 4:31 PM
    #37
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Definitely sounds like a throughout bearing chirp. My throwout bearing replacement was covered by the 5yr 60K mile powertrain warranty.
  18. Jul 17, 2012 at 4:36 PM
    #38
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Similar thing happened to me. The clutch literally slipped on the friction rivets and needed to be replaced. Warranty took care of it. The tech wanted to replace all but they wouldn't let him. I eventually had the same squeak. Took it back and it needed a new throw out bearing and shift fork. Needless to say, the tech threw that in his boss' face!
  19. Jul 17, 2012 at 4:49 PM
    #39
    wvugis78
    wvugis78 Well-Known Member
    VA
    2016 Sport 4x4 MT 5100's, / 2009 TRD Sport 5100's, Franken Pack Leafs
    I had the same problems with my 2005 6 spd. Two transmissions and then at the end had TB wear. Basically your input sleeve develops ridges and the OME bearing is narrow and wobbles and then fails. You can drive on a bad throw out bearing for a while but the noise is bothersome. Pull the inspection plate on the divers side and turn your truck on in N. You will see it dancing. I used the Tranquil after talking to the owner of the shop that makes them. http://pdmusa1.com/ I bought the part and toyota installed it for free and it voided the warranty of the clutch only. Well worth it. Their are TSB on this issue.
    Good Luck.
  20. Jul 17, 2012 at 5:07 PM
    #40
    iroh
    michigander
    tonneau
    Looks like the URD TOB fix, just priced $105 higher. Did you find their manufacturer perhaps?
    Check this out--
    pic on URD website
    pic on pdmusa1:
    oh snap!
