Tranny issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dynarider15, Sep 16, 2020.
  1. Sep 16, 2020 at 8:38 PM
    Dynarider15
    Dynarider15 [OP] Member
    Hey
    I have a 2017 dclb. Around 50miles an hour if I step on the throttle as to pass a car or merge. the truck will jerk a bit and go. The jerk is felt from the back end kind of it’s hard to tell to be honest. If I coast and feather the throttle I can make the truck jerk the same way. Any suggestions where to look? I feel the truck shifts from 6th to try fifth and goes into fourth gear. Some one told me to look at the slip yoke/joint? It doesn’t make any grinding noises etc. Just a leg or jerk. Has anyone else has this issue or point me into what to look for
  2. Sep 16, 2020 at 10:51 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    that's pretty normal for these transmissions. although it's more of a surge than a jerk... i always drive with s-mode on 4 or 5 to prevent that behavior.
  3. Sep 16, 2020 at 10:59 PM
    tcjacado
    tcjacado Well-Known Member
    Are your u bolts loose. Check the torque on them.
    Sounds like axle wrap.
    hiPSI likes this.
  4. Sep 16, 2020 at 11:09 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    ACIS..
  5. Sep 17, 2020 at 7:44 PM
    Dynarider15
    Acis?
  6. Sep 17, 2020 at 7:45 PM
    Dynarider15
    Could it be from 2 inch lift block in rear?
  7. Sep 17, 2020 at 7:47 PM
    tcjacado
    Yes, potentially.
    Try tightening the u bolts though.
    hiPSI likes this.
  8. Sep 17, 2020 at 7:51 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Where's the tranny jokes? It's only an hour until Friday so let's go man!
    tcjacado[QUOTED] likes this.
