Tranny/Oil Temp Gauges
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 503TRD, Apr 3, 2011.
  1. Apr 3, 2011 at 3:18 PM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    I searched and found alot of threads about this already, but none had any answers. I would like to hook up an oil pressure gauge, and a tranny temp gauge. Anyways, I was wondering what needs to be done, and it it's even possible to do this on my 2010 trd sport, automatic transmission. Does the oil sandwhich adapter between the filter work well? Idk, I just need to know everything I need and need to do so I can try. Also what temperature ranges would I need for them?
    Would any of these work? Or would I need additional stuff?
    Tranny Temp:
    http://www.glowshiftdirect.com/elite-10-color-transmission-temperature-gauge.aspx
    Oil Pressure:
    http://www.glowshiftdirect.com/elite-10-color-oil-pressure-gauge.aspx
    Oil Sandwhich adapter
    http://www.glowshiftdirect.com/oilfiltersenderadapter-20mm15thread-1.aspx
    What size adapter would I need, or is there a better way
    Or these, are they better?
    Tranny:
    http://autometer.com/cat_gaugedetail.aspx?gid=3948&sid=76
    Oil Press:
    http://autometer.com/cat_gaugedetail.aspx?gid=3944&sid=76
    Additional info is helpful and appreciated. Thanks in advance
  2. Apr 3, 2011 at 3:51 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You goign to have problem getting any of these in Toyota. Oil pressure is complicated because our sending unit is dummy and only takes minimal pressure. Sandwich plate may not work with out cutting that splash guard around the oil filter.
    As far as tranny temp goes there is no place to put the temp plug other then where the drain plug is (and thats not very good place to begin with)
  3. Apr 3, 2011 at 5:19 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Aeroforce sells a guage that does tranny temps..little pricey but i hear it is a superb product!
  4. Apr 3, 2011 at 7:50 PM
    Alex Segal
    Alex Segal Member
    North Florida
    09 Tacoma Dcab longbed
    scanguage II,prodigy3 brake controller, softopper
    I needed trans temp gauge because I do a lot of towing. I got tired of waiting for scangauge to come up with the codes, ever time I call they say "One more month" for the last three years.
    I bought an aeroforce and it works great. Here is a great link for interpreting transmission temperatures and implications for your tranny.
    http://kamperbob.com/images/TransTempChart.html
  5. Apr 3, 2011 at 9:32 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    If you know which trans temp line is the output hot side you could stick the sender in a tee in that line. Be easy to plumb in. I did it on my car, works fine.
    It may not be the optimal point but sometimes you don't need a totally accurate measurement as much as you need to know when you're running outside of the normal range so you can back it off some.
  6. Apr 3, 2011 at 11:40 PM
    503TRD
    503TRD [OP] Trucker
    Chad
    Tualatin, Oregon
    Yeah, anyone know which line(s) I need to go into? and where would it be located?
  7. Apr 4, 2011 at 8:21 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    The service manual says that maximum normal ATF operating temperature is 80C/176F.
    The transmission will store a DTC and turn on the Check Engine Light if the ATF temperature reaches 110C/230F (2 trip detection logic). It alters shift point and lockup if the ATF temperature reaches 130C/266F. It turns on the overheat warning light (if provided) at 150C/302F.
  8. May 11, 2011 at 2:06 AM
    WiltSF
    WiltSF Member
    Redlands
    10 PreRunner
    TRD Intake, 4000K HID Fog Lights, 6000K HID Head Lights
    The Glowshift adapter works awesome, I use it on both my GTI and Taco with the Elite series.
  9. May 11, 2011 at 6:29 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
