tranny pan bolts stripped now leaking...how to fix ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jerbo29, Oct 14, 2024.
  1. Oct 14, 2024 at 9:19 AM
    jerbo29
    jerbo29 [OP] Member
    Coastal Calif. Aptos, Santa Cruz County
    2003 taco 4 x 4
    just did a change of gen1 2003 automatic tranny. pulled pan, changed the filter. buffed off all of the old gasket remains from the pan & tranny housing. sprayed 3-m adhesive to pan edged then pot black rubber gasket in place, smoothed down gasket to get even, flat purchase.
    cleaned dip stick filler tube ends. put a few dabs of silicone on the lower end of dip stick tube [the smaller diameter facing down part. jammed a rag down the dipstick filler tube on tranny pan to clean out so it would seal when added to the upper dip stick tube. put silicone on top of the tranny gasket then pushed the pan in place connecting dip stick tube. used bail wire to keep tranny pan up and began to thread bolts on opposite ends to keep & in place. some of the silicone went into bolt holes, so i rushed to get all bolts in before that stuff got hard...some bolts were hard to hand thread, so i used my pneumatic socket wrench hoping that potting some pressure on the bolts, that they would just go. i screwed up 3 bolt threads and they just spin, never tightening up. now i got a slow leak where two bolts are not pulling the pan tight enough to seal it. how can i either re-thread the 3 screws that just spin? re tap them i size larger or wat? thanks Greg
  2. Oct 14, 2024 at 9:32 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    If they're an M6 thread you can probably run a 1/4" SAE tap in and put 1/4" bolts in the holes that are stripped.
  3. Oct 14, 2024 at 10:55 AM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Jakerou likes this.
  4. Oct 14, 2024 at 11:13 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Manual transmission swap…
    or M6 helicoil kit, whichever is easiest for you
    ControlCar likes this.
  5. Oct 14, 2024 at 11:19 AM
    PaulyFromLA
    PaulyFromLA Well-Known Member
    Pauly
    1st gen tacomas
    Ones a camper, ones oem, ones a flatbed
    manuals suck, just helicoil it
  6. Oct 14, 2024 at 11:45 AM
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    Blasphemy! You sir are a not a real man. (J/K)
  7. Oct 15, 2024 at 12:37 AM
    PaulyFromLA
    Pauly
    1st gen tacomas
    first vehicle was a tacoma with a 5 speed, no thank you, drove tht fucker for 3 years everyday, sold it and have always had autos
