Tranny pan/plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thillman, Oct 8, 2018.
  1. Oct 8, 2018 at 8:09 AM
    Thillman
    Thillman [OP] Well-Known Member
    '12 Tacoma TRD Off-Road
    so my drain plug is officially spinnin and begging a very slow drip. going to need to top the fluid off and start the whole check level procedure again.
    i’m beginning to think that 21 lbs/ft
    is the wrong torque on these drain plugs, i saw 16 on another thread, yet both how to’s definitely state 21.
    regardless, i need to act fast here. i’ve read all about different oversize plugs etc. unless somebody can convince me otherwise i’m thinking swap the pan.
    has anybody found a after market transmission pan ANYwhere? all i can find is OEM. rockauto doesn’t even carry.
    additionally what is yalls preferred sealant and brand pan gasket while we’re at it?
    i believe the nut inside the pan broke loose, my plug washer is oem, torque was spot on, not cross threaded but just flat over torqued at 21 lb/ft
    all voices welcome
    BrokenMech likes this.
  2. Oct 8, 2018 at 9:06 AM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Welcome to the club, 21 ft lbs stripped mine also. With the threads being wet with oil the torque value must be less.
    I bought one at a dealer web site. It was about $85 shipped.
    I like Fel Pro or Toyota gaskets with no sealants, haven't used any other brand to compare.
    I'm betting the drain plug stripped.
    Thillman[OP] and BrokenMech like this.
  3. Oct 8, 2018 at 9:14 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Did you replace the crush washer on the level plug and drain plug? There are both part # 35178-30010. It is my opinion these crush washers do not reuse well. They are just that - "crush" washers and are very soft.
  4. Oct 8, 2018 at 9:43 AM
    BrokenMech
    BrokenMech Well-Known Member
    Upstate, NY
    2019 4Runner TRD Pro
    I did the exact same thing. I stripped the plug at 21lb/ft. I got a new pan/plug, crush washer, and oem rubber seal for the pan.
    Put everything back together and torqued it just below 21 lb/ft and left it at that. Like 15 lb/ft but I can’t remember. Like it was mentioned before the plug threads have oil on them so they can be torqued a little lower.
    You could probably find a cheaper route but I just decided to replace everything and it’s been fine.
    Hope you work it out.
  5. Oct 8, 2018 at 12:51 PM
    Thillman
    yeah, i’m a bit anal about it.
    thanks for the input. this is one of the reasons i like doing my own work, and yet here we are. no sealant no issues huh? good to hear!
  6. Oct 8, 2018 at 12:52 PM
    Thillman
    yep, seeming like i’m going to be biting the bullet. i’m at the point where i’m going and getting a new 3/8 torque wrench to replace my harbour freight special, just eliminate everything.
    thanks again.
    also, did any of y’all reuse your old fluid?
    BrokenMech[QUOTED] likes this.
  7. Oct 8, 2018 at 1:01 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I thought the trans bolt torque was 15 ft/pds, I always torqued mine to 10-11 ft/pds because they will easily strip
  8. Oct 8, 2018 at 1:24 PM
    Thillman
  9. Oct 8, 2018 at 1:25 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    After reading about people stripping the pan bolt, when I change out just the pan fluid, I put on a new washer and slowly tighten it by hand, I could feel the washer crimp and snug up, and that’s when I stopped with the pressure.I don’t think I could have felt that with my torque wrench. So far no leaks.
    NAAC3TACO and BrokenMech like this.
  10. Oct 8, 2018 at 2:04 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Hand tight with a wrench is all you ever need on drain plugs,never had a single problem or leak in 40 years.
    BrokenMech and Jimmyh like this.
  11. Oct 8, 2018 at 2:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This. I have never used a torque wrench on a drain plug, ever.
    BrokenMech and b_r_o like this.
  12. Oct 8, 2018 at 2:23 PM
    lynlan1819
    Tacoma
    Lifted
    Exactly.
  13. Oct 8, 2018 at 4:26 PM
    BillsSR5
    bill
    2014 SR5
    I'm not sure but maybe the threads on the pan can be retapped at the same pitch. That sucks because I know those trans plugs are very susceptible to stripping i only go to 10 ft/pds. Cause I'm scared shirtless to strip them
  14. Oct 8, 2018 at 5:27 PM
    BrokenMech
    Upstate, NY
    I got new fluid just to be through since I had replaced everything else. But I don’t see why you couldn’t reuse the old fluid if you wanted to save some cash.
  15. Oct 8, 2018 at 5:34 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I purchase a 1/4 drive harbor freight torque wrench and it never felt quit right. After using it a while I took it to work and had our calibration department check it. It was read 21 in lbs high at the low end and about 40 in lbs high at the high end. High enough I was lucky I never broke any bolts. Being it didn't feel right I was always setting it on the low side. Anyway, I took it apart, put it back together, had it checked again and it's now with-in a few in. lbs. Harbor Freights certificate of calibration is meaningless, not worth the paper it's printed on.
  16. Oct 8, 2018 at 5:57 PM
    BillsSR5
    bill
    2014 SR5
    I use the old beam style Craftsman torque wrench
  17. Oct 8, 2018 at 8:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I am shocked!
  18. Oct 9, 2018 at 5:46 AM
    SebSA
    SebSA Active Member
    2013 DCSB 4x4 4.0 Auto
    21 ft lb was too much for mine too. For me the plug was what stripped and the pan was fine. Unfortunately I only noticed this after ordering a new pan and plug. I had just dropped the pan and replaced the gasket, so I only replaced the plug and all was good. Never have gone to 21 again.
    Unless you need to drop your pan, I suggest looking at the plug to see if that is what stripped before dropping the pan.
  19. Oct 22, 2018 at 6:48 AM
    Thillman
    I would hope it’s just the plug, yet when trying to tighten it just keeps spinning, never goes hand tight. I’ll feel some resistance and then it it breaks loose and keeps going. I suppose the threads on the plug could be flattened in one place and therefore don’t bite causing it to misalign again.
    I would hope that all pans are made to be harder metal than he plug. Seems logical to strip the plug before the pan. But I don’t know.
    I topped my fluid with a leftover bottle, did the level check procedure until I can get the extra money together to do the whole thing properly. After this I have a hard time trusting any precarious procedure like the level check or torque. Hell with using a torque wrench again
  20. Oct 22, 2018 at 6:52 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Same here. Some people overthink this shit. Probably people out there that torque their license plate to specs as well.
    :rofl:
    Muddinfun likes this.
