Tranny pops into neutral easily
Discussion in '1st Gen. Tacomas (1995-2004)' started by DIRT YOTA, May 15, 2012.
  1. May 15, 2012 at 2:21 AM
    DIRT YOTA
    DIRT YOTA [OP] Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Like the title says my transmission will pop into neutral when I go over even small bumps or whoops now. It use to only do it on big hits, but now I pretty much have to drive with a hand holding it in gear(offroading of course). I've read about adjusting the linkage;
    http://www.tacomaterritory.com/forum/showthread.php?t=154437&highlight=Shift+linkage+adjustment
    But is there a more solid or permanent fix anyone knows of? Mine will go from 1st to neutral so easy it sucks! Any help is appreciated!
  2. May 15, 2012 at 8:58 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    So your auto? If so you need to adjust the linkage so it goes completely into gear, if manual, you have a bad shift fork.
  3. May 15, 2012 at 11:30 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Yes I'm auto, sorry that may be useful.
    No body lift!!!!
    My shifter lines up perfect with the gear it's in, when in drive it shows perfectly in drive. I've seen some not line up well which would lead me to linkage adjustment. Even if it lines up adjusting the linkage will fix this problem? Also will it still line up after? I'll check the tranny mounts again before I adjust the linkage.
