Tranny problem. I was in New Mexico @ 10k' when my 16 off-road died in the highway. Message said tra
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phawk, Aug 12, 2016.
  1. Aug 12, 2016 at 6:51 AM
    phawk
    phawk [OP] Active Member
    Phillip
    2016 Tacoma TRD OR
    In NEw Mexico @ 10K' when my 16 off-road died in the highway. Message said hot trans. After 15-20 minutes restarted and back to camper. Called toyota service at home and they said don't lock it in a gear (2nd) pulling a hill. It was shifting from 2nd to 3rd every 10 seconds so I put it in second and ran 2300rpm for a minute or two just before it died. I said Ok they said wont happen again. Next day drove 20 miles normal speed it died again same message. Turned for home died every 5 miles till I got there. Same message
    Truck has 20K miles and is totally under under warranty. No one in NM wants to come get it without me paying 4-500$ up front for the tow. Pissed off loaded it back on the trailer, hooked up Motorhome, cut vacation 1 month short and hauled ass home dropping it off at local dealer. After two weeks of whatever they do I should get it back today with a new converter. Happen to anyone else?
  2. Aug 12, 2016 at 6:53 AM
    MisterDrew
    MisterDrew Member
    drew
    2017 DCLB TRD Sport
    Geez. Does it have the tow package with coolers?
  3. Aug 12, 2016 at 7:01 AM
    GueroSteve
    GueroSteve Member
    Southern California
    2016 DCLB TRD-OR
    Prior to this, did you get the TSB done and have your ATF checked?
    Sorry to hear, that really sucks. I can't imagine how stressful that'd be, especially if you had family with you.
  4. Aug 12, 2016 at 7:02 AM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Going up a hill at 2300 RPM in 2ND gear for 2 minutes killed it? That's hard to believe. Did I read that wrong?
    This sound similar to the crankshaft position sensor issue that has been leaving people stranded. Did they check that sensor was operating correctly?
  5. Aug 12, 2016 at 7:09 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    IIRC, you have to hit 300° for that warning. Best case, your atf is probably fried.
    James_Bond and Aussiek2000 like this.
  6. Aug 12, 2016 at 7:12 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Yeah the 2nd gear thing sounds fishy to me... I have a manual and drive at 2300 rpms all day long, thats the sweet spot for highway speeds and where I get the best mpg.
  7. Aug 12, 2016 at 7:14 AM
    transworldmoto
    transworldmoto Well-Known Member
    Ben
    California Coast
    2016 Access Cab TRD OR 4X4
    Was it slipping or did you feel it losing power as it was shifting constantly between 2nd and 3rd? Just curious, since this would be a good indication of low fluid. Also curious to hear if you have a trans cooler with the tow package or not!
  8. Aug 12, 2016 at 7:20 AM
    Lv4Tacos
    Lv4Tacos Well-Known Member
    Mn
    2015 Base AC 4x4
    None
    "Truck has 20K miles and is totally under under warranty. No one in NM wants to come get it without me paying 4-500$ up front for the tow."
    With the truck being under warranty, why didn't Toyota tow it to the nearest Toyota Dealer? Isn't that covered under Roadside Assistance?
    azrokttec, jmaack, dutchjim and 10 others like this.
  9. Aug 12, 2016 at 7:22 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    How slow are you going to be in 2nd gear? How much weight? Factory tow package?
  10. Aug 12, 2016 at 7:24 AM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Yeah I was thinking why not call Toyota roadside assistance hotline, if it's under warranty doesn't the manual say that it's free towing.
    specter208, BGXtobe, Large and 3 others like this.
  11. Aug 12, 2016 at 7:32 AM
    George1441
    George1441 Much happier
    George
    2016 Chevrolet Colorado Diesel
    I was wondering why they hit you up for a tow bill if you have the Toyota Care for the first two years. That really sucks that they didn't honor that
  12. Aug 12, 2016 at 7:45 AM
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    Fuck I'm often running 4500-5000RPM in S3 or S4 up long steep grades for 5-10 minutes. Often several times over a few hours in the mountains. This way I can avoid constant shifting between 3-4-5. If this is not advisable I'm fucked because I can't handle the constant shifting on grades!
  13. Aug 12, 2016 at 8:13 AM
    phawk
    Phillip
    2016 Tacoma TRD OR
  14. Aug 12, 2016 at 8:19 AM
    oldschoolczar
    '16 DCSB TRD OR
    Have them check your crankshaft position sensor. It's becoming a common failure. I think I recall 1-2 CPS failures that indicated the same way as your issue (tranny overheating)...
  15. Aug 12, 2016 at 8:22 AM
    phawk
    Phillip
    2016 Tacoma TRD OR
    Not sure how to add info to a previous message. Santa Fe toyota said I was too far away. To call toyota assistance. Did that they called a tow service $400 over the $100 they paid. Warranty should apply. I'll get my chance to question their policy once it's fixed. Truck has tow package with cooler
    DesertTaco4x4 likes this.
  16. Aug 12, 2016 at 8:22 AM
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    Due to the circumstances reported (towing and 'hunting' gears) I could be wrong. BUT, mine acted exactly the same, including trans temp light, start/stop, when it was the crankshaft position sensor.
  17. Aug 12, 2016 at 8:27 AM
    phawk
    Phillip
    2016 Tacoma TRD OR
    Left out part of it. When my dealer worked on it first week they said nothing was wrong. Computer showed hot converter but worked fine. I picked it up drove it 30 miles check engine light came on took it back to them. Say they're putting a converter in it. Didn't quit me that time. They did the shift update the first week.
  18. Aug 12, 2016 at 8:46 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Sweet new engine and transmission, such a good choice by Toyota. Hope the step up to the plate as a company worth anything should, and fix ALL these trucks.
    Mclovin80 and CarolinaSport like this.
  19. Aug 12, 2016 at 8:58 AM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    Get that crappy OEM Tranny fluid flushed out completely and refill with AMSOIL Low Viscosity Signature Series ATF and add Dr Tanny Additive and a bottle of LubeGard Platinum Tranny Additive to tranny, this will cure and protect for 60-75,000 miles,but I flush mine every 30-40,000 miles,Tranny way to expensive to R&R !
    AdventureKid likes this.
  20. Aug 12, 2016 at 9:20 AM
    phawk
    Phillip
    2016 Tacoma TRD OR
    Couldn't even get the service foreman to check the fluid or smell it to see if burnt. They are installing a catalytic converter not a torque converter. I'm not ready to trust it to Mars and back like my 15 YO landcruiser
