Tranny questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoham, Jan 24, 2016.
  1. Jan 24, 2016 at 5:27 PM
    Tacoham
    Tacoham [OP] Member
    Dumb questions, but here goes.
    I have a 2002 Tacoma V4 5-speed 4WD with an R150F manual transmission.
    1. Does the designation R150F INCLUDE the transfer case?
    2. Does this tranny/transfer case have an oil pump(s) that must be driven by the engine running?
    3. I want to tow this truck 4-down (i.e. flat tow) it with all four wheels on the ground with tranny and transfer case both in neutral. Can this be done?
    4. During a tow, will the (4?) wheels drive the transfer case and cause damage?
    The owners manual says no towing allowed, but I'm told by many that this Taco CAN be safely towed with both transfer case and tranny in neutral.
    Thanks in advance for some answers.
  2. Jan 25, 2016 at 4:37 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Oh boy, dumb questions.
    1. Yes and no. The R150F is designated as a RWD/4WD tranny, the transfer case is an additional component.
    2. The engine powers the internal pumping action.
    3. Dunno. Would be safest to do on a flatbed or front up as is usually done. No need to worry about locking steering then.
    4. Answer would be based on #3
  3. Jan 25, 2016 at 5:56 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    I don't think the R150F pairs with a 4 cylinder truck unless it was modified. More likely you have a 3RZ motor paired with a W59 transmission.
  4. Jan 25, 2016 at 9:04 AM
    Tacoham
    Tacoham [OP] Member
    My error .... My taco IS a 6-cylinder engine (5VZ-FE). I'm away from the truck now but I'm certain the tranny is a R150F.
  5. Jan 25, 2016 at 9:12 AM
    Tacoham
    Tacoham [OP] Member
    So I can (do?) have selectable 2WD (rear) or 4WD with low or high range with my R150F tranny only and NO transfer case? There are TWO shifters: one for 1-5 speed and a second shifter for 2WD/4WD low range/high range. I always thought a transfer case contained the 2nd shifter?
  6. Jan 25, 2016 at 9:55 AM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    The tranny and transfer case are two separate components. The transfer case bolts to the output of the tranny. If you have 4wd, you have a transfer case. And yes, the transfer case has the second shifter. I wouldn't tow it 4 down without manual lockout hubs, which I don't believe were an option on 2002 models.
  7. Jan 25, 2016 at 9:56 AM
    MrRiverMan
    WNC
    The transfer case usually contains the second shifter. You must have a transfer case if you have 4x4. If your transmission is an R150F, then you have a 4x4 transfer case bolted to the back of the transmission. They look like all one thing, but they are actually separate. If you had 2x4, you would have an R150 transmission with no transfer case bolted to it.
    The pics below are of a W59, but it's the same idea. The first pic is of the transmission and transfer case bolted together. The second pic is of the transmission split from the t-case. You can see the holes where the shifters go - one hole on the trans and one on the t-case.
  8. Jan 25, 2016 at 9:58 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    No, the short answer is no. The transfer case has a pump and it is driven from the engine/transmission side. The only way to safely tow a Taco with all four on the ground is by disconnecting the rear driveline. The front doesn't matter as long as its in 2WD.
  9. Jan 25, 2016 at 9:58 AM
    MrRiverMan
    WNC
    For towing 4 down, I recommend disconnecting and removing both driveshafts. Make sure you mark each end of the shaft and the flanges so you can put them back in the exact orientation you found them in once you're done towing. This will keep anything from turning in the transmission or t-case.
  10. Jan 29, 2016 at 9:09 AM
    Tacoham
    Tacoham [OP] Member
    The OP here ...
    Thanks for the replies all.
    I've decided to drop the rear driveshaft from the differential and just 'tie' it off to the frame or hang it under a chassis support member, then leave the transfer case in 2WD, and tranny in neutral. I haven't tried it yet, but I think dropping the D-shaft is a 15-minute job. And ... I've read several posts about trouble with those $$$ (Remco) D-shaft disconnect kits.
    Remember, I'm not simply towing my Taco from A to B but using it for local transportation & exploring when I arrive at various RV campsites.
    Oh, some say I should also disconnect the front wheels D-shaft as well. Is that really necessary and why?
  11. Jan 29, 2016 at 4:20 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    If you have manual hubs i wouldnt bother disconnecting the front drive shaft.
    If youve got auto hubs i personally would disconnect the front to keep the whole front end and transfer case from spinning...
