Tranny Shift Rod lever moves with any road imperfection ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by oracle, Sep 12, 2011.
  1. Sep 12, 2011 at 10:41 PM
    oracle
    oracle [OP] Member
    Calgary, AB, CANADA
    03' DC 4x4 TRD, Ltd and Moonroof 3.4lt Taco
    bunch of miles, scars and dirt..
    Hi
    Today I noticed the shift rod lever moves almost 1/2" when the road is uneven or if I hit the gas a bit too much.
    Is that normal? First thing I thought was the tranny mounts are shot and truthfully I haven't checked so I don't know but has any of you noticed that?
    Or is it possible the engine mounts and/or read diff is a bit loose?
    Any thoughts?
    Note: Truck is double cab, TRD 4x4 with Auto tranny.
    Thanks
  2. Sep 12, 2011 at 10:56 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    this has been a concern on taco forums since 2001....
    not sure about 1/2" of movement, but our trucks have this type of floating tranny... supposedly the lack of a rigid tranny keeps em from the effects of stress, yada yada yada...
    although, still check your mounts just to be safe...
    i once felt my steering being sloppy and clicking...
    thought it was alignment.. turned out my steering rack was loose so i tightened the bolts and problem solved...
    so for sure check your motor mounts and tranny mounts...
  3. Sep 13, 2011 at 1:19 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yeah mine does the same when I accelerate and whatnot!
    maybe I should check my bolts too...
  4. Sep 13, 2011 at 3:59 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Check your blinker fluid.
    Low levels of blinker fluid cause a starvation resulting in uneven pressure when the fluid shifts to one side from a road imperfection.
    :D
  5. Sep 13, 2011 at 11:13 AM
    tacoman78
    tacoman78 Well-Known Member
    Bakersfield, CA
    02 Limited Dbl Cab Prerunner
    Deck Mod
    Hey don't forget to pick up 2 quarts elbow grease while your at it.
  6. Sep 13, 2011 at 11:21 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Transmissions are mounted to the truck with rubber mounts as opposed to a solid mount. It allows the trans. to move around causing less stress, so said.
  7. Sep 13, 2011 at 2:54 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Dammit
  8. Sep 16, 2011 at 8:03 AM
    oracle
    oracle [OP] Member
    Calgary, AB, CANADA
    Update:
    I noticed that if I engage the 4x4 mode (push button) the play in the rod is significantly less. Anyone else has noticed that?
