Tranny SHUDDER Toyota Certified RIPOFF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by applebmw, Feb 21, 2013.
  1. Feb 21, 2013 at 5:17 PM
    applebmw
    applebmw [OP] Active Member
    Lonnie
    Greenville, Ohio
    09 PreRunner
    Bought a 09 PreRunner 7,000 miles ago with Toyota Certified Warranty, they telling me it shudders because fluid needs changed in tranny, NOT COVERED under warranty.......$160 per change, may take up to three times....Any Help here ? been reading about spill and fill, three quarts at a time, prolly same thing there doing.....Anybody had the problem?? Results?? I going to do myself in garage
    OK, UPDATE....I changed trans fluid.13Qts,,,,,,,09 PreRunner DOES Have a atf light when you use jump wire as explained, tells when hot enough to check.....It STILL Shudders,,,going back to dealer tommorow for further checking, Hope they take care of it this time, Cost me $135 for the fluid..plus time.
  2. Feb 21, 2013 at 5:19 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    if its the shudder everyone has, its not your tranny fluid.
  3. Feb 21, 2013 at 5:19 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    When ever I asked Toyota people about trans fluid, they always say it NEVER needs to be changed. How many miles you got on that truck?
  4. Feb 21, 2013 at 5:21 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Please explain your shudder. It could be suspension related more than trans.
    Also how many miles are on the truck? Trans fluid changes are not recommended even by the dealer, some state lifetime fluid or 100K.
    We all know trans fluid breaks down as its life goes on so some here do it every 30-50K.
  5. Feb 21, 2013 at 5:31 PM
    applebmw
    Lonnie
    Greenville, Ohio
    09 PreRunner
    bought truck with 57k miles, has 62k miles now, shudders at 40-42 mph in overdrive, 1200-1300 rpm, just kinda passes throu, can't get it to do constant, just started last 200 miles,,,,,,,,,,they say replace tranny fluid, if that does not work, tearing into tranny...
  6. Feb 21, 2013 at 5:35 PM
    applebmw
    Lonnie
    Greenville, Ohio
    09 PreRunner
    so what is it??
  7. Feb 21, 2013 at 5:44 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the driveshaft center bearing for excessive play. Get underneath and grab the driveshaft and push and pull (side to side) there should be very little play. On my old truck the thing must of had 8" side to side play.images_8da6eab13be0231a326472a86b5b89a9a0a4f58c.jpg
  8. Feb 21, 2013 at 5:44 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    That would be the driveline/suspension shudder that is typically at take off to 30mph. Varies from vehicle to vehicle from leaf springs being weak, trans level due to mount/crossmember, carrier bearing, pinion angle etc. There is a couple of TSB's on this but not many reach a cure.
    Yours sounds like converter and or converter lock up based on mph and rpm.
  9. Feb 21, 2013 at 6:01 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
  10. Feb 21, 2013 at 6:03 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Mine does the same thing
  11. Feb 21, 2013 at 6:03 PM
    650H1
    Michael
    VA
    OP, tighten your U-bolts (hold your leafs in place) to 90 ft lbs of torque. thatll fix your issue.
  12. Feb 21, 2013 at 6:25 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Mine does it as well. If you want to drain n fill your trans, it's pretty simple. My drain n fills have been 4 qts. Here are some helpful links.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/68462-diy-full-flush-automatic-transmission.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/63851-how-drain-refill-automatic-transmission.html
    Good luck
  13. Feb 21, 2013 at 7:10 PM
    applebmw
    Lonnie
    Greenville, Ohio
    09 PreRunner
  14. Feb 21, 2013 at 7:12 PM
    OZ-T
    Peter North
    British Columbia
    Not the U bolts
  15. Feb 21, 2013 at 7:46 PM
    applebmw
    Lonnie
    Greenville, Ohio
    09 PreRunner
    Local trans shop says replace fluid, drive couple days, if does not fix, replace again, These guys are pro's, i know/trust em. say the converter making the shudder, water in fluid, moister, Believe gonna try it, after I get truck back from Dealer....why is it after pricks get your $$$ for car, they not even return phone calls about problems??? Toyota Direct, Columbus OHIO...basturds
  16. Feb 21, 2013 at 11:46 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    Make sure trans fluid level is spot on. These trans are very picky about trans level. So if you are doing the work yourself and trans shifts odd or even worse afterwards double check level after driving a bit to verify full circulation.
    I feel your pain on the extended warranty, check my thoughts by my screen name, it has been that was since I bought my truck as well.
    I had luck recently getting a bunch of work done before my ext platinum warranty expired. Got a new wheel bearing, water pump and fan motor so it is possible for them to be nice and grant work to be done but it seems like it pullling teeth.
  17. Feb 22, 2013 at 2:33 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I have 40k miles since my last drain n fill. I did it 3x, with the last at 50k. I plan on doing a major service in about 4k miles, which all fluids will be replaced. I didn't notice this hesitation between 40-45mph til about 5k miles ago, but when I drained n refilled, I did notice the trans shifting much nicer than previously. I wouldn't guarantee that draining and refilling will alleviate the shudder, but it won't hurt. Best way to get rid of the shudder is not to drive up hill, in OD, at 40-45mph. That's where I notice the shudder the most. Others may have different input though.
  18. Feb 23, 2013 at 5:46 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    My shudder at take off was cured by a u-joint replacement covered under warranty. I was and still am skeptical but that's what they told me they did and with 40K on the repair it hasn't returned.
  19. Feb 23, 2013 at 6:01 AM
    gearcruncher
    Canadain bumper technician
  20. Feb 23, 2013 at 6:10 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    What engine do you have? I have a V6 DCLB 4x4 and I have a shutter at 40mph consistent. I believe it's a shift point and its just not quite sure what to do... I do have a take off shutter as well. What your describing sounds like the shift point. If you drive 40 and stay at a constant speed does it feel like its chugging?
    I hardly think you need to change your fluid...
