Tranny squeal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MNYota, Jul 10, 2020.
  1. Jul 10, 2020 at 8:49 AM
    MNYota
    MNYota [OP] Member
    David
    Minnesota
    2001 Toyota 4Runner SR5, 2010 Tacoma SR5 Sport
    Work in progress
    Fairly new to Tacomas. 2010 SR5, V6, 4x4 with a 6-speed manual.
    Just recently, when sitting with the truck running, I’m hearing a faint rotational squeal. If I just very lightly touch the clutch pedal, it stops. Not even hard enough to disengage the clutch. Very light pressure. Pull my foot away and it starts again. It’s not loud at all.
    Any ideas what that might be?
    Thanks in advance!
  2. Jul 10, 2020 at 9:09 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Almost certainly your throw-out bearing. Not sure about 2nd gen Tacomas, but I know with older Chevs (S-10/S-15) it was a sure sign that you were on a count-down to a gernading bearing. I'm sure others can chime in with more experience on whether this is something you need to worry about or not.
    HolycityTaco and TexasWhiteIce like this.
  3. Jul 10, 2020 at 11:03 AM
    MR5X5
    MR5X5 Well-Known Member
    This :thumbsup:
  4. Jul 10, 2020 at 11:58 AM
    MNYota
    MNYota [OP] Member
    David
    Minnesota
    Work in progress
    Yeah, that’s what I was thinking. Have a shop do it or DIY? Tough stuff on a Tacoma?
  5. Jul 10, 2020 at 12:28 PM
    tirediron
    It's a PIA driveway job on a 4x4 unless you have a lift of some sort (or tall jackstands) and a transmission jack, but it's definitely do-able. You'll probably save yourself about a grand, but it will likely take a full weekend unless you have some experience.
  6. Jul 11, 2020 at 2:24 PM
    PNWTAC0MA
    PNWTAC0MA Well-Known Member
    Jessee
    Washington State
    2007 DCSB 6-Speed Manual
    Toytec boss lift Trd Pro rep grill Spec D headlights LED fog lights ARE Canopy
    Might be the TOB chirp that all M/T owners deal with including myself. Have heard of a few temporary fixes but nothing set in stone. Was considering replacing the TOB for a clutchmaster TOB paired with a exedy clutch when mine is due for a change. Many have had better luck with the Clutchmaster TOB & have heard some folks on here go with the URD TOB but have had the "chirp" come back 10-20k miles later.
  7. Jul 11, 2020 at 3:58 PM
    tirediron
    Tranny squeal? Maybe his panties are too tight?
    Micbt25 likes this.
