Tranny woes 2010 automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10TRDOFFROAD, Jul 30, 2010.
  1. Jul 30, 2010 at 4:02 PM
    10TRDOFFROAD
    10TRDOFFROAD [OP] Well-Known Member
    Jamf
    Las Vegas
    10 TRDOFFROAD Quad 4x4
    Originally posted this thread in the new member Forum. My bad. I have a 2010 quad cab TRDOFFROAD 4x4 with 12000miles on it. About 2000miles ago I started noticing a clunk coming from the Rear end?(I think) when coming to a stop. Then, another clunk upon removing my foot from the brake. It dose not clunk when I put the truck in neutral and stop. It was driving me nuts. So I took it to the stealership. And they concurred that their was indeed a " clunk in the brake pedal and that Toyota was aware of the problem and that their was no fix at this time. So upon finding this awesome web site. Thanks to you people I was informed of a TSB re-flash on the tranny to make the shifting smoother. So I took it back and the stealership re-flashed the tranny and upgraded my rear springs(Another TSB) Too make a long story short. They told me the clunk was drive-line lash. And that it was normal. My mechanic told me he has a 4 Runner and it dose the same thing..... Dose anyone else have this issue? And am I out of options.. thanks for your time..:mad:
  2. Jul 30, 2010 at 4:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Doesnt sound normal to me. You shoudl try a different dealer.
  3. Jul 30, 2010 at 4:15 PM
    10TRDOFFROAD
    Jamf
    Las Vegas
    Ive been to two dealers. The first one said there was no fix. the second said it was normal.......
  4. Jul 30, 2010 at 4:17 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    I get that every once in a while. Don't think it's anything to worry about. Have read that a good grease job of the spline takes care of it. There also appears to be "clunk" issues related to leaf spring "windup" and/or axle wrap... think people confuse terms. But it's related to the soft leaf springs (3-packs). But you say that you got those replaced with 4-packs. So is the "clunk" better, worse or less now?
    More reading for you - http://www.yotatech.com/f2/tacoma-clunk-2627/
  5. Jul 30, 2010 at 4:28 PM
    10TRDOFFROAD
    Jamf
    Las Vegas
    The same.....As far as Axel wrap goes. The symptoms are there at 2mile an hour as well as panic stops. So i don't think its axle wrap. Also I hit all the zrks on the drive line.
  6. Jul 30, 2010 at 4:47 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    It's "normal". I say it quotations cause Toyota may come out with a fix for it later down the line but as for now there's no fix for it so we are told that it's a normal condition. At least that's what the engineers tell me every time I ask when they come to my dealership
  7. Jul 30, 2010 at 5:41 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    lol, what is going on with all these toyota issues. It's like the worse it gets the more they ignore it and hope it goes away
  8. Jul 30, 2010 at 5:44 PM
    acmair
    acmair Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    My 99 Corolla does that same thing. It started off as you said, but now it does it all the time, and progressively gets worse. I'm going to try to replace the struts on it, and check the brakes.
    But Tacomas are different. Just to clarify, you said it happened when you pressed on the brakes at slow speeds or just slow speeds in general? and does it happen when you go over a bump, or even on a perfectly smooth road?
  9. Jul 30, 2010 at 5:54 PM
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    Oh great another problem ill probably have to deal with.
  10. Jul 30, 2010 at 6:35 PM
    10TRDOFFROAD
    Jamf
    Las Vegas
    After the vehicle comes to a stop. Just as the truck "settles" Their is a nudge. It happens 98% of the time. Smooth road or off road same thing. It also bumps or nudge after pedal release(brake).
  11. Jul 30, 2010 at 6:42 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    sounds like normal axle wrap
  12. Jul 30, 2010 at 6:47 PM
    10TRDOFFROAD
    Jamf
    Las Vegas
    Even at 1 to 2 mph stops?
  13. Jul 30, 2010 at 6:47 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    OP mine does the same thing, from what I've read it seems to be normal.
  14. Jul 30, 2010 at 6:50 PM
    acmair
    Andrew
    That's exactly what my Corolla does. If I find a solution, I'll let you know!
