Tranny!!
Discussion in 'Technical Chat' started by HDFD10, Nov 29, 2009.
  1. Nov 29, 2009 at 12:15 PM
    HDFD10
    HDFD10 [OP] Well-Known Member
    I am an idoit! First time changing oil on my 06 tacoma and not paying attention. Pulled the tranny drain plug instead of the oil !! So now i have an empty transmission, no big deal but how the hell do you put new fluid back in it?? Can not find a dipstick or fill or anything??? PLEASE HELP!!
  2. Nov 29, 2009 at 12:17 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Welcome to TW! Sorry it is on such unflattering terms. However, you are definitely not the first person to do this. The tranny is serviced at the dealership. If there is a way to refill that I am not aware of, someone will be here soon...
  3. Nov 29, 2009 at 12:19 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    :smack: :facepalm:
    Someone will be along shortly or track down chris4x4.
  4. Nov 29, 2009 at 12:21 PM
    98tacoma27
    Ben
    Not Beech Creek
  5. Nov 29, 2009 at 12:22 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    His wife wouldn't have just recently had a baby would she?? and his name might be ..... Krazie :D
  6. Nov 29, 2009 at 12:22 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  7. Nov 29, 2009 at 12:22 PM
    HDFD10
    Glad to know i am not alone, but of anyone that has done this how can i fix it? I got a truck with a drained tranny sittin half way out of the garage!! I am pretty upset with myself right now
  8. Nov 29, 2009 at 12:23 PM
    98tacoma27
    Ben
    Not Beech Creek
  9. Nov 29, 2009 at 12:43 PM
    HDFD10
    Sorry guys not really following along here. So there is a FILL opening on the passanger side of tranny and i open the CHECK plug and fill it up in the FILL opening unitll it runs out the CHECK opening?? Is this correct?? And do i do this with the truck running of off. And do i need to buy ATF from toyota or can i get ATF from local auto store??
  10. Nov 29, 2009 at 12:46 PM
    ImpulseRed008
    Susan
    SC
    Read this... tells you everything you need to know...
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/61731-transmission-gurus-i-need-help-fast.html
  11. Nov 29, 2009 at 12:52 PM
    HDFD10
  12. Nov 29, 2009 at 12:58 PM
    ImpulseRed008
    Susan
    SC
    Yes, you have to use toyota genuine ATF WS.
    Remove the refill plug and overflow plug. Fill until fluid trickles out the overflow tube.
    good luck.
  13. Nov 29, 2009 at 1:00 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    I have not done this so take what I say with a grain of salt...but it sounds like you have the right idea. Except that the truck needs to be running and the trans fluid needs to be at the proper temp to get an accurate check.
  14. Nov 29, 2009 at 1:04 PM
    HDFD10
    So guess my truck is out of service untill the dealer opens back up on monday. SH!T..!!! I feel like such a jacka$$.. I sure hope all goes well and i dont have any problems with my tranny now..:confused:
  15. Nov 29, 2009 at 1:18 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    After reading about this on here and other forums if I was you I'd call a tow truck and have it serviced at the dealership....getting the fluid back in is kind of a complicated process on these sealed units. Also, from what I've read you want to go with the fluid Toyota recommends...good luck.
  16. Nov 29, 2009 at 3:27 PM
    HDFD10
    How many of you guys have done this accidentally and how many have fixxed it no problems? I am not sure i know where this FILL plug is after crawling back under it and am getting a little nervous but cant exactly afford to visit the dealership either:mad:
  17. Nov 29, 2009 at 5:55 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    so after I turn off my truck
    it was make this knock ping noise from the engine.
    i got a reply from an other person here say it is bad...
    then how do I fix it? and cheap? thanks!
