Trannyoil change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hawki, Apr 13, 2015.
  1. Apr 13, 2015 at 2:04 PM
    Hawki
    Hawki [OP] Member
    Ed
    Calgary AB, Canada
    Is draining the oil from the pan the same oil coming out of the drain plug on the transmission. I have a '99 tacoma, v6 auto, 4x4. Thanks
  2. Apr 13, 2015 at 2:27 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    There should be two plugs, one for engine oil and one for transmission.
    The transmission oil should have a much stronger smell and a reddish colouring.
  3. Apr 13, 2015 at 4:14 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  4. Apr 13, 2015 at 4:30 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
  5. Apr 13, 2015 at 4:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Careful with that tranny, Ed. images_e207ad861ca5e565afb693e12982ef3353385825.jpg
