Trans collar causing trans failure
Discussion in '1st Gen. Tacomas (1995-2004)' started by BohlaaH, May 18, 2017.
  1. May 18, 2017 at 6:24 AM
    BohlaaH
    BohlaaH [OP] Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    asking for my dad - he said that there is an issue when the rad begins to break down it causes the transmission collar to allow antifreeze to mix with the transmission fluid. How prevalent is this issue? Can anyone input on this. Thank you for anything!
  2. May 18, 2017 at 7:59 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Google, "Toyota Tacoma Strawberry milkshake'....
    I'm 100% serious
