Trans Cooler 2025 Tacoma 4x4 TrD
Discussion in '4th Gen. Tacomas (2024+)' started by Billcfolsom, Jan 26, 2025.
  1. Jan 26, 2025 at 2:06 AM
    Billcfolsom
    Billcfolsom [OP] New Member
    Are exterior transcoolers available? I live in 100 degree areas in the summer and tow alot.
    Bill
  2. Jan 26, 2025 at 5:07 AM
    GrrrMaker
    GrrrMaker 2024 Tacoma SR5 4x4
    Woodstock, GA
    2024 Celestial Silver SR5 4x4
    DV8 OE Plus Side Steps MCX Skid Plate Bonobo Front Recovery Points Bonobo Hitch Recovery Point (2" Soft Shackle) Redline Hood Struts Volume Knob for 8" Infotainment Screen (TacoMods on Etsy)
    In my experience, that comes as part of the tow package. Quick Google search for the 2024 Tacoma towing package indicated transmission fluid cooler is included
  3. Jan 26, 2025 at 5:12 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Tacoma's haven't had the external cooler since 2020-21ish? Only cooler now is through the radiator.
    shakerhood and Newwt like this.
  4. Jan 26, 2025 at 5:19 AM
    GrrrMaker
    Woodstock, GA
    That's good to know. I know I had an external cooler in my 2013 TRD sport. Is the radiator integrated transmission cooler not good enough for Desert temperatures?
  5. Jan 26, 2025 at 5:29 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    If you're driving bare and not towing, it's fine. But, there's videos out there of 4th gens towing near max and the transmission temps were VERY hot. Modern fluids can handle it better, but they (temps) got way to high for what I personally like. I don't hardly ever tow, so no biggie to me, but guys that tow would benefit greatly from an external cooler.
  6. Jan 26, 2025 at 5:40 AM
    GrrrMaker
    Woodstock, GA
    Well, I tow a 3400 lb popup, so this might be an issue for me hauling up grades in the Rockies/Sierras. Thoughts?
  7. Jan 26, 2025 at 5:43 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Most experience I have is towing that amount up a mountain pass around 2200ft with a 3rd gen and had no issues. I'm not a towing guy at all, but I would try it and keep an eye on the trans temp and see what happens. I'm sure once the experts wake up they can advise better.
    I have not personally seen any threads on an external cooler installed on a 4th gen here.
    GrrrMaker[QUOTED] likes this.
  8. Jan 26, 2025 at 8:22 AM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    I'm in the same boat. All I do is keep monitoring the transmission oil temperature gauge. So far, no issues.
    GrrrMaker likes this.
  9. Jan 26, 2025 at 8:39 AM
    Billcfolsom
    Thanks, everyone. Yes, I've read their internal report and agree that the test run videos reflect the transmission fluid running very hot under hot weather conditions. A few seem aware of this. My question, as I am not a mechanic, is: can an additional external cooler be added, and would it make a difference?
  10. Jan 26, 2025 at 8:58 AM
    caribe makaira
    Caribbean, Puerto Rico
    Yes
    and
    Yes
    BabyBilly likes this.
  11. Jan 26, 2025 at 9:03 AM
    GrrrMaker
    Woodstock, GA
    Our first big summer camping trip is this summer, but that's just the Appalachian chain. Likely next summer will be Northern Rockies. That'll be the real test.
  12. Jan 26, 2025 at 9:06 AM
    4x4spiegel
    4x4spiegel Well-Known Member
    and would it effect Toyota warranty ?
  13. Jan 26, 2025 at 9:12 AM
    GrrrMaker
    Woodstock, GA
    That's the real rub, isn't it?
    4x4spiegel[QUOTED] likes this.
  14. Jan 26, 2025 at 9:21 AM
    caribe makaira
    • 6-speed manual (RC60F)
    • 8-speed automatic (AL80E/F)
  15. Jan 26, 2025 at 9:25 AM
    caribe makaira
    This is a 4th Gen Tacoma, not a 3rd Gen.
  16. Jan 26, 2025 at 9:34 AM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    This post has been deleted. I was trying to explain the two drain plugs and how to refill and refresh using the Gen 3 diagram.
  17. Jan 26, 2025 at 9:39 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    On some models I’m assuming ones with the tow package, there is a transmission water cooled hear exchanger on the right side behind the radiator along with cooling lines going to the radiator
  18. Jan 26, 2025 at 3:45 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I don’t experience 100 degree ambient temps - but I was having highish AT temps while towing up hills so I added a cooler to my 3rd gen. BUT the real problem was to climb the hills the engine would be revving way up to 3000 or more RPM and the cooling system would be inadequate. The new engine produces enough torque down low (1700 RPM) to hopefully avoid this situation. I’ll find out when the snow melts in a couple months. I tried to hook up my scan gauge but the torque converter temp is not reporting- maybe has a new code?
    Delta09[QUOTED] likes this.
  19. Jan 27, 2025 at 11:06 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    PDKTaco likes this.
  20. Jan 28, 2025 at 5:04 AM
    Dbarffish
    Doug
    Montana
    Stock
    Those temps are pretty high. Didn’t overheat - true - but I would not like to be running those temps for extended periods of time. I’m hoping my towing at highway speeds doesn’t have these temps.
    OregontoBajaCA likes this.
