Trans Cooler 2025 Tacoma 4x4 TrD
Discussion in '4th Gen. Tacomas (2024+)' started by Billcfolsom, Jan 26, 2025.
  1. Jan 28, 2025 at 6:06 AM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    Post link: 4th gen scanguage trans temps
    I posted some XGauge codes that show the transmission oil pan temps and one that can show the torque converter lockup status if that's of any use.
    Torque converter code:
    Other post link 4th gen scanguage trans temps
  2. Jan 28, 2025 at 6:55 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    do you plan on towing a small car up a very long grade in the mountains on a hot day very often? if the answer is no then why are you worried ?
  3. Jan 28, 2025 at 8:45 AM
    Vitamins
    2024 TRD OR
    I like to keep my options open. Chance favors the prepared.
  4. Jan 28, 2025 at 10:43 AM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    I can relate. While I suppose I’m not particularly worried about it since Aisin has been making solid transmissions — bar casting cleanliness issues, anyway — for quite some time, my natural reaction to a truck with an automatic is that I want it to have an auxiliary transmission cooler.
    It’s probably from watching my dad’s several GM trucks all have one transmission issue or another that ended up being related to inadequate cooling, and his long term solution being to install the inevitable GM OEM trans cooler they should have put on at the factory. GM’s got a long and sad history making crappy transmissions in general, so it’s probably not anything I should worry about unless I somehow end up with a truck with a bow-tie on it. You could see why I’d be worried, though.
