Trans Cooler Installed
Discussion in '1st Gen. Tacomas (1995-2004)' started by cruisedon66, Dec 7, 2017.
  1. Dec 7, 2017 at 9:40 AM
    cruisedon66
    cruisedon66 [OP] Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I thought I'd share photo's of the transmission cooler install I completed.
    2003 Tacoma 2WD. 2.4 Ltr.
    The transmission cooler is from www.etrailer.com part #D13503.
    I didn't want to add any more heat to the existing radiator & A/C.
    I found a spot in the air flow below the bumper. The top of the cooler is behind the bumper, but still should get air movement. I don't do a lot of towing anyway. This is just to keep transmission temps down , adding to longevity.
    Photo #1 The mounting location at the base of the radiator.
    Photo#2. An aluminum bar with speed clips attached. This will fit behind the "blind" lower mounting radiator support. (new holes drilled on trans cooler frame)
    Photo #3. The aluminum bar in position. I ran the bolts in just to make sure it would line up. ( a small section of wire helps guide it in position. Loosening the A/C condenser helped too.)
    Photo #4 & #5. Installed.
    Tip....(I forgot this myself.) Fill the trans cooler off car to find out volume of A/T Fluid.
    After installation, just add the volume to transmission.
    UtahTacoma02 likes this.
  2. Dec 7, 2017 at 12:26 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Beautiful.
    cruisedon66[OP] likes this.
  3. Feb 15, 2021 at 12:41 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Great write-up looking to do something similar
  4. Feb 15, 2021 at 6:02 PM
    Appalachia Man
    Appalachia Man Well-Known Member
    03 Prerunner X-cab
    2.7L Detroit Truetrac 2" lift OME 880's & Dakar's
    agreed. already on my 2nd radiator. thats the sweet spot right there.
