Trans cooler/radiator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Smuffins, Oct 17, 2022.
  1. Oct 17, 2022 at 4:35 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    More math is fun! So they saved $1.6M. Good on them.
    Let's assume that the average selling price for those 644K Tacomas was $30K. That means they had sales of over NINETEEN BILLION DOLLARS.
    More math, carry the one, add two...
    That is 0.000087% savings....
    erok81[QUOTED] likes this.
  2. Oct 17, 2022 at 4:38 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    whoa rainbow warrior thats wrong
  3. Oct 17, 2022 at 4:41 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    How are you guys seeing the temp of the transmission? Something in the settings?
    RIX TUX likes this.
  4. Oct 17, 2022 at 4:51 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Get bent mad magazine. Go check your truck
    mic_sierra likes this.
  5. Oct 17, 2022 at 4:54 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    That’s about the same in my second gen - 220’s heading up the mountain to 5K from 500 feet. Went into the 230’s a few weeks ago, westward from El Centro Ca into the mountains on I8 but ambient temp was 105+ and I had luggage for three. And it had an oem trans cooler. Now has an upgraded Hayden. I have an Ultragauge to measure temps.
  6. Oct 17, 2022 at 4:57 PM
    RIX TUX
    the trans cooler is in the radiator, its not deleted
  7. Oct 17, 2022 at 4:58 PM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    I think we all know I'm referencing the external trans cooler that came with every Tacoma with a tow package since about 2005. So I repeat, get bent mad magazine
  8. Oct 17, 2022 at 5:04 PM
    RIX TUX
    both type of coolers are external if they are not in the trans
  9. Oct 17, 2022 at 5:35 PM
    erok81
    erok81 Well-Known Member
    Imposter
    So you are saying because it’s only x% of sales it’s not worth it? If only companies thought that way we’d probably still have trans coolers. :rofl:
    hiPSI[QUOTED] likes this.
  10. Oct 17, 2022 at 5:52 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Pretty much every auto transmission has been cooled by the engine coolant for 50+ years. That's nothing new. Toyota deleted the secondary external cooler.
    33yrsoftoys and blu92in99 like this.
  11. Oct 17, 2022 at 5:56 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Naw, there are practical limits though. For example, we spent several hundred thousand to land a customer that will never spend that much. Stupid decision.
    Maybe it sped up the line by not installing the external cooler? More efficient? Maybe external cooler only gave a degree or two? Wh knows but I don't know many companies who go out to the 7th decimal. There is a law of diminishing returns.
  12. Oct 17, 2022 at 6:13 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Why all this anxiety about tacoma automatic transmissions failing due to overheating? I’ve not heard of a single case of this.
    RIX TUX likes this.
  13. Oct 17, 2022 at 7:07 PM
    erok81
    Imposter
    True. But also keep in mind there isn’t much work to get that 1.6M. It’s just updating some parts and assembly instructions. Also sure it’s a low % but if you have multiple groups all shaving off millions it adds up. At least that’s how it’s worked for me when I’ve had to shave money off.
    Lastly I think you might have an extra zero in there (assuming I followed what you were mathing). ;)
  14. Oct 18, 2022 at 12:18 AM
    Smuffins
    Smuffins [OP] Member
    2022 Lunar Rock Off-Road
    I think part of it is the availability over the past decade of monitoring tools. I’ve noticed myself constantly checking my ultragauge even with nothing in tow.
    meanwhile five years ago I was pulling something at the top of my old Subarus weight rating up a 10 mile hill without a care in the world
  15. Oct 18, 2022 at 7:14 AM
    #35
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Yep. Pulling 3500# from Breckenridge through to Denver I saw TF1 and TF2 temps of 240* F up to the Eisenhower-Johnson tunnel and I was getting close to pulling over if it went a degree over 240. It didn't. That was taxing on my Taco but I didn't do it any favors with a stock tune, stock gears, and 275/70/17 KO2s. I normally see TF1 temps in the 190 - 205 range through the Wyoming mountains and TF2 will briefly spike to 210 - 220 and then back down to 190 - 195.
    I did the trans flush using the fill and replace method from Tim the Toolman's YouTube (disconnect the ATF cooler return line and use the Taco's pump to flush out the old fluid... flush a quart, fill a quart, flush and fill so on and so forth for 12 quarts). At 30k miles despite the occasional spike to 220, 230, and 5 minutes of 240* F the trans fluid had plenty of pink. It looked good.
    I'm still installing a Setrab aux cooler in the near future though. I was not comfortable with TF1 and TF2 getting to 240*F on CO-9 and I-70 through the Rockies.
    skeletron[QUOTED] likes this.
  16. Oct 18, 2022 at 7:21 AM
    #36
    mic_sierra
    Elsewhere
    Check out how many issues are fluid / heat related in this AAMCO blog post. That is why.
    Edit: it isn't Tacoma specific, it is AT specific. I had the same level of concern in my 3/4 ton diesel Ram.
    33yrsoftoys and skeletron like this.
  17. Oct 18, 2022 at 7:44 AM
    #37
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    This is true. We all call it the cooler in the radiator but it's really more of a trans temp regulator. Auto transmissions should run between 180°-190°. We all know temps above this aren't good for the trans, but what most don't know is temps below aren't good for it either.
