Trans cooler?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mechanized82, Jul 1, 2019.
  1. Jul 1, 2019 at 6:12 AM
    Mechanized82
    Mechanized82 [OP] Member
    Do manual TRDs with a tow package have a trans cooler or is that just for automatics?
    I got a used tacoma, it seems to have everything included in the tow package except that.
  2. Jul 1, 2019 at 6:57 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    If you've got a manual trans, you don't have a factory installed trans cooler. Autos only...and they need it. Manuals don't unless you plan on slipping the clutch the entire time you're driving...but then you've got bigger wear problems.
  3. Jul 1, 2019 at 7:15 AM
    Mechanized82
    Yeah, I wasn't sure if it was a cooler meant for transmission gears or the converter on ATs. Makes sense though. Good to know. I'm only towing around 3k (1300lb trailer, 2 motorcycles 1000lbs, with odds and ends probably bring me close to 3k) so it sounds like I'll be fine.
