Trans cooler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eltaco0809, Aug 3, 2020.
  1. Aug 3, 2020 at 8:26 AM
    Eltaco0809
    Eltaco0809 [OP] New Member
    Tacos
    Needs some suggestions, I got a 09 Tacoma prerunner, with no towing package. I’m in the process of installing the necessary to tow. This includes aux trans cooler. Is it best to fill the aux cooler up or should I run thru the gear and fill what’s needed from the plug at the transmission?
    I figure I would probably have to fill up either way, but wouldn’t it Be less if I fill the radiator up when I install it. Thanks everyone for the input!
  2. Aug 3, 2020 at 8:29 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    When was the last time the trans fluid was changed? If anywhere close to 60k miles on the current fluid id take the opprotunity to do a flush.
    Id install the cooler and leave the return line to the trans disconnected. Then using the DIY posted here, pump all the old fluid through the new trans cooler, this will flush any contaminants out of the trans cooler and fill it at the same time.
  3. Aug 3, 2020 at 8:39 AM
    Eltaco0809
    Tacos
    I have not flush the fluid since I had it! The truck has over 120 k . I took it to a three shops and all stated that if the trans wasn’t having any issues at 120k that it wouldn’t be suggested to change it because it would probably cost some issues or it might not lol.
  4. Aug 3, 2020 at 8:53 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  5. Aug 3, 2020 at 9:03 AM
    nd4spdbh
    SoCal
    Do the DIY full flush after installing the cooler to flush the new cooler too like stated. Your trans will thank you.
  6. Aug 3, 2020 at 9:05 AM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    Just having recently installed and Aux Cooler with Fan. It was NOT possible to fill it prior to install because of the location of the inlet and exit ports.. thinking about your question, it would be a total mess of transfluid leaking everywhere if you tried to fill even if it was hooked up to the flow. Go with your first suggestion, fill through the pan. I would ensure on the return line, by unhooking and putting on a flex tube that the transfluid is returning and has pushed out all the air, then hook back up and fill as needed through the pan.
