Trans cooler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wdunnlee, Feb 25, 2025.
  1. Feb 25, 2025 at 2:21 PM
    wdunnlee
    wdunnlee [OP] Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    Did all second gens come with a trans cooler? The little on in front? Wanted to upgrade mine but I guess he ran away… or I’m :duh:Challenged…
    I wanted the mishimoto one but will that not work if I don’t have a trans cooler from the factory?
  2. Feb 25, 2025 at 2:25 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    All 2nd gens have a trans cooler/heater internal to the radiator. Only 2nd gens with the tow package have the additional external cooler.
    You can install an aftermarket cooler on both (and typically people with the tow package ditch the external one when adding the aftermarket cooler). Generally you would want to route the circuit as follows: Trans > internal cooler/heater > external cooler > trans return.
    I have the Hayden Automotive 679 on mine.
    1 Limited Toyota likes this.
  3. Feb 25, 2025 at 2:27 PM
    wdunnlee
    Will
    Tidewater VA
    Got it, I’ll look for some diagrams from people who have done it. The mishimoto one is designed to replace the tow package cooler. Can I use that one or do I need a special kit? Maybe I’m over thinking it and it’s pretty simple :fingerscrossed:
  4. Feb 25, 2025 at 2:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  5. Feb 25, 2025 at 2:37 PM
    wdunnlee
    Will
    Tidewater VA
    Hypothetically say I lied to y’all, and already bought the mishimoto cooler a week ago… :bananadead:
    It looks like I can just use the tubing, and just add it in like a circuit. Trans-> radiator-> cooler->trans. But do I need more tubing than it comes with because it assumes I already have the tow package. It comes with brackets so I am good in that department.
  6. Feb 25, 2025 at 2:38 PM
    nd4spdbh
    SoCal
    Haha that works. Just note that if you dont have something like the internal bypass cooler with a built in thermostat or an inline thermostat you can actually OVERCOOL the transmission fluid if you live in a cooler climate.
  7. Feb 25, 2025 at 2:43 PM
    wdunnlee
    Will
    Tidewater VA
    As far as I know it doesn’t have that. But what I do have is a scan gauge 3 and eyes :D. What’s a good temp range? When I’m just driving around town will this be too much you think? I guess I could return it and get a bypass system.
  8. Feb 25, 2025 at 2:52 PM
    hoffengineering
    Taylor
    2015 DCLB 4X4
    If you do need extra hose, you can buy bulk hose online or at an auto part store. Just look for automatic transmission fluid hose; typically it will be nylon braided nitrile rubber hose.
    I believe the correct size is 5/16" ID (or for our trucks, 8mm ID, but 5/16" is easier to find and almost exactly the same size at 7.9375mm), but I would measure yourself to be sure.
    The 165-175 range is generally considered ideal.
    wdunnlee[QUOTED][OP] likes this.
  9. Feb 27, 2025 at 6:47 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The A750 transmission docs call out a normal operating temp of 68F-230F - these numbers from Aisin, not Toyota, and are engineering data that doesn't reflect the application. Note that on the high end, this is cooking the hell out of your ATF, cutting service life drastically - more than 50% reduction IIRC from the heat decomposition tables for WS ATF. Toyota says normal temp range in the Taco is 122F-175F.
  10. May 12, 2025 at 3:56 AM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Mine is avg 174 with it going up to 204 down the highway with some minor hills.
    My water runs 186-193 .
    My 2000 4runner always stayed 20 degrees under water temp.
    I have the external tow cooler from Toyota but prefer the temp to be lower.
    I’d replacing the Toyota tow cooler with the Hayden the best option and what difference can I expect.
