Trans fluid change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GIJO, Jul 9, 2019.
  1. Jul 9, 2019 at 11:44 AM
    GIJO
    GIJO [OP] Member
    4wd trd off road
    Recently I changed the transmission fluid I was guided by a Hanes manual. I drained old fluid replaced filter and gasket then added new fluid. I put 3 gallons in let the truck warm up then released the overflow bolt and let drain until a trickle then tightened the bolt up. Now my truck is shifting hard from neutral to drive the truck jumps. Does anyone know the correct procedure for replacing trans fluid. It’s a 2013 Tacoma v6 4wd with tow package. My guess is that because the bolt says check and not overflow there should always be enough in the transmission for some to drain to check the condition of the fluid. Before I drained the excess there was no hard shifting so I’m thinking that maybe I should just add until it doesn’t hard shift and then be done with it. Any insight would be greatly appreciated thanks in advance.
  2. Jul 9, 2019 at 11:52 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  3. Jul 9, 2019 at 12:00 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    You basically did a pan dump, a pan dump done correctly should have been a tad over 3 qts.
    3 gallons, yikes!
  4. Jul 9, 2019 at 12:13 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Not sure about 3 gallons... You mightve put in 2-1/4 gallons too much.
    Gus87 likes this.
  5. Jul 9, 2019 at 12:19 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Hoping you meant quarts.
  6. Jul 9, 2019 at 1:30 PM
    GIJO
    GIJO [OP] Member
    4wd trd off road
    So I’ve put too much I can deal with that but exactly how do I go about correcting this. What steps do I take to know for a fact that I’ve got the right amount.
  7. Jul 9, 2019 at 1:32 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
  8. Jul 9, 2019 at 1:42 PM
    GIJO
    GIJO [OP] Member
    4wd trd off road
    Can adding too much result in the hard shifts I’m experiencing? It’s only from neutral to drive and it shifts just fine while driving.
  9. Jul 9, 2019 at 1:56 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    It’s not that easy. You need to get the transmission into a certain temperature range then pull the check bolt.
  10. Jul 9, 2019 at 1:59 PM
    GIJO
    GIJO [OP] Member
    4wd trd off road
    I did that but if I’ve put over two gallons too much it should drain the two gallons out but it might drain a quart then it stops I really don’t know what to do now
  11. Jul 9, 2019 at 2:16 PM
    ARB1977
    North Texas
    You need to read the transmission temp. Either a Bluetooth adapter and app or scan gauge or put it in temp check mode. Water temp isn’t the same.
    When I did mine I drained what was in the pan. Poured it into a gallon jug. Mark a line on the jug. Use that to measure what pump s out of the transmission via cooler return line. Ended up using 12 qrts.
