Trans Fluid - Need Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RevivalOL, Nov 30, 2018.
  1. Nov 30, 2018 at 7:48 AM
    RevivalOL
    RevivalOL [OP] Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    Well I made a ridiculously STUPID mistake today, and I need help/confirmation on what to do next.
    I was about to start an oil change, and I was in a rush (don't do this). Not thinking, I pulled the trans drain plug instead of the oil pan plug. SHIT. I was able to get the plug back in after losing only about 1qt of trans fluid. So two questions:
    1. I assume it's ok to just get 1-2qts of ATF WS fluid and top off at the trans fill plug, replacing what I dumped?
    2. Auto parts store is 2.5 miles away. Can I drive there to get the ATF, or should I wait a day until I can get there without taking the truck?
    Any help is appreciated.
  2. Nov 30, 2018 at 8:19 AM
    RevivalOL
    Pete
    Berkley, MI
    Got it. I'm going to wait and drive to the dealer later and buy the Toyota WS. I caught all the drained fluid in a pan and can measure it exactly, so I'll feel ok putting that much back in. Thanks for the reply - makes me feel a bit better.
    Vbpiper likes this.
  3. Nov 30, 2018 at 8:28 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Do not use a torque wrench on your transmission drain plug!
    It will break! Just tighten like a normal person. There’s like 3 threads there
    over60 likes this.
  4. Nov 30, 2018 at 8:31 AM
    trdsilver
    trdsilver Well-Known Member
    So Cal
    2016 TRD Sport 4x4
    OVTune, King 2.5", Total Chaos UCA's, Icon RXT Leaf, Icon Rear Bumps, Pelfreybuilt Silders, JL Audio, Cali-Raised LED, Toyo RT 285-70-17
    I do not know anyone on here that has changed the transmission fluid on their 3rd gen at home. These transmissions are more complicated to work on. You will most likely need to go to a dealer or a Toyota specific shop. Heads up, that oil is EXPENSIVE.
  5. Nov 30, 2018 at 8:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Are you saying it will break using the published torque spec?
  6. Nov 30, 2018 at 8:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    over60 and hiPSI like this.
  7. Nov 30, 2018 at 8:43 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I would take it to the dealer and let them add precisely how much is needed. Unless you are willing to do the exact fill procedure and it's fairly complicated.
  8. Nov 30, 2018 at 9:24 AM
    Radarninja
    Northern California
    06 taco
    Yes, yes I am.
  9. Nov 30, 2018 at 9:28 AM
    RevivalOL
    Pete
    Berkley, MI
    I got the Toyota ATF WS fluid to refill it. 1.1 quarts came out. I'm going to put 1.1 quarts back in and then get it to the dealer to have them service it properly for peace of mind. That said - is the fill plug in the same spot as on the 2nd Gen's? I can't find a picture or diagram of the 3rd Gen to confirm that the fill plug is in the same spot.
  10. Nov 30, 2018 at 9:53 AM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Quite a few people on here have checked and added transmission fluid from their home. There should be a few big threads on it. Sounds like OP just needs to add fluid and properly check fill level. A few good threads on here detailing how to do so.
    Now if he wants to completely change out all fluid that’s another story.
  11. Nov 30, 2018 at 10:26 AM
    RevivalOL
    Pete
    Berkley, MI
    You guys were a big help. I borrowed a friend's car, drove to the dealer and got the ATF WS. Measured what I dumped, and put back in same amount, plus a tiny bit assuming some was left in the catch pan. Buttoned up and test drove. Going to check fill level tomorrow, but it seems I'm safely back in business for the rest of the day. Time for a beer.
    Vbpiper likes this.
  12. Nov 30, 2018 at 10:39 AM
    B33
    B33 Well-Known Member
    2017 tacoma TRD Sport
  13. Nov 30, 2018 at 11:34 AM
    trdsilver
    So Cal
    2016 TRD Sport 4x4
    Yeah that's what I was talking about. My neighborhood oil change shops don't have the tools to change the transmission fluid.
  14. Nov 30, 2018 at 11:43 AM
    trazerr
    Oregon
    Yeah, I wouldn’t trust a neighborhood oil shop to top off my windshield fluid reservoir let alone my transmission haha
    As long as you have some sockets, an allen wrench, funnel, and piece of wire you should be set. Plus fluid of course. Extra pair of eyes wouldn’t hurt either.
