trans fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 604YOTA, Oct 3, 2013.
  1. Oct 3, 2013 at 8:41 PM
    604YOTA
    604YOTA [OP] Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    My truck has 185,500 miles. I need to do my trans fluid.
    Should I just empty and refill. Or do a full flush.. have heard horror stories about high mile full flushes..:confused:
  2. Oct 3, 2013 at 8:46 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    do you think or know if its ever been done? thats alot of miles. I would say flush and filter screen change that way the pan can be cleaned of all the sediment
  3. Oct 3, 2013 at 8:58 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    No clue when it was last changed that's why I'm wanting to get on it.
  4. Oct 3, 2013 at 9:02 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Il get on ut this weekend
  5. Oct 6, 2013 at 10:23 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Don't flush.
    Even if you screen, it's a bad idea. Gear bits and metal shavings rolling around in there from years of shifting have probably reintegrated into the transmission, meaning they're as integral as they were before they broke off.
    When you flush, you push all those shavings out and either jam them up somewhere else they're not supposed to be or the transmission will slip more often without those pieces doing their job.
    Drain. Refill. Done. If your tranny has accumulated a lot of this crap then you basically drive it till it's dead and buy a new or used one.
  6. Oct 6, 2013 at 10:46 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    Yes, go to the dealers and get 4qts. of Toyota T-IV auto fluid a new drain gasket for the plug. Use only Toyota T-IV fluid not DEX III or others. I have same truck,drain pan plug is 10mm I think replace with new gasket about 12 ft/lbs. with torque wrench don't strip it. Pull out trans. stick in engine bay use funnel to pour in the new stuff slowly. the owners manual says it takes 2.1 liters but that's a misprint it will take all 4 qts. to fill a pan drain.
