Trans fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Riley0226, Jan 25, 2025.
  1. Jan 25, 2025 at 7:27 PM
    Riley0226
    Riley0226 [OP] Active Member
    98’ Tacoma sr5 4x4
    Was changing my diff fluid today and noticed my pilot bushing (I think) was leaking some trans fluid. Let the truck warm up for a while and drove around for 5-10 minutes, checked the fluid and it was low. Below the cold mark. I’d like to top it off with some new fluid before I get it into a shop to get taken care of. The problem is I’m not sure what trans fluid is in there since I just bought the truck. Can I mix different fluids? Would anything go wrong if I put in some valvoline dex/merc in but the old fluid is Toyota t4? Sorry if it’s a stupid question, just don’t wanna play around with the transmission. Thanks for any input. Truck is 98 sr5 4x4 automatic
  2. Jan 25, 2025 at 9:10 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Look at the dipstick. It should be on there. Toyota ATF dipsticks are stamped with the fluid they take.
    if checking only, start at step c4
    https://www.tacomaworld.com/threads/high-mileage-2002-prerunner-diff-oil-trans.833159/#post-29857418
    oldtimertoyota likes this.
  3. Jan 26, 2025 at 5:59 AM
    02hilux
    Planet: EARTH
    My understanding:
    4cyl = TIV
    6cyl = Dex
    If the atf drain bolt is original, it will be stamp which type of fluid. If it’s calling for TIV, I wouldn’t add the blue bottle Val Dex/Merc, I would use the red bottle Maxlife.
    Moonrman likes this.
