Trans Flush ?'s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sloppyjoe, Jun 7, 2011.
  1. Jun 7, 2011 at 7:26 AM
    sloppyjoe
    sloppyjoe [OP] They are more like guide lines.
    All Over
    Silver and simple
    Non
    So I am due for the trans flush on my Tacoma, and was wondering if anyone has ever had it done at another place, other than the dealer? I have a local shop that performs this service on our trucks and it is a bit less expensive with this group. This is a great shop locally and has a wonderful rep for good honest work, is there anything I should be looking for before using them? Should I not chance it and have the dealership do it? I do not have a warranty, and would perfer to use this shop, but will not if I get the direction that I should not from others here. Any help would be great.. Thanks!!
  2. Jun 7, 2011 at 7:49 AM
    JKD
    JKD Well-Known Member
    Make damned sure they're using the correct WS fluid.
  3. Jun 7, 2011 at 10:12 AM
    sloppyjoe
    All Over
    Silver and simple
    Non
    Yeah I knew the fluid was important, but I was just curious if others had any luck with outside services? I may still go with the Dealership though.
  4. Jun 7, 2011 at 11:06 AM
    warfrik
    warfrik New Member
    I would not take the chance. Just take it to the dealer. I was on the same boat as you. I ended up paying $180+ at the dealer but I had the piece of mind.
  5. Jun 7, 2011 at 1:06 PM
    sloppyjoe
    All Over
    Silver and simple
    Non
    $180 would not hurt my feelings so much. They want $300 for it here! I feel that si a bit too high, I would have been fine with $250 even but $300 just sounds like robbery to me.
  6. Jun 7, 2011 at 1:07 PM
    JKD
    If you trust the local shop, I would have no problem with it, so long as they can assure you (and you believe them) that they will only be putting genuine Toyota WS fluid in the transmission. That should be in writing, on the estimate and on the receipt when it is finished and paid for.
  7. Jun 7, 2011 at 1:17 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    There is a DIY on transmission oil change in the 2nd gen section, check it out. You'd save yourself a ton of cash. And flushing isn't all that hard either. Check out the DIY and if you feel you need it flushed, which if it's the 60k change I personally don't think you do, just buy a hand pump for the fluid bottle and pump through your trans cooler lines.
  8. Jun 7, 2011 at 1:20 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    went thru this with a retro T-Bird with sealed trans like the Tacomas and no local shop would touch it said needed special tools etc to properly evacuate and replace the fluid. actually Tuffys said they would do it but having done my homework i quized them and after they looked it up on their computer they backed off and said they could not do it. i would call other dealers for price that seems a bit high but in the end would go with the dealed on this one.
