trans noise at idle, goes away when I clutch in
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco47, Oct 7, 2014.
  1. Oct 24, 2014 at 4:09 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
  2. Oct 30, 2014 at 9:48 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Just as an update to this thread, my W59 transmission (pictured above) that had this problem of noise in all gears except 4th wound up having a bad countershaft carrier bearing. Unfortunately, it disintegrated enough that it scored the countershaft horribly, to where it had to be replaced ($$ouch!$). The transmission now has all new bearings and synchros as well, and I'll be putting the shift forks back on in a few minutes.
    Currygoat likes this.
  3. May 12, 2016 at 1:14 PM
    Xyphon112
    Xyphon112 Well-Known Member
    So I have a very, very pronounced whine in gears 1,2,3 but none in 4th, so I'm assuming based on your info that my countershaft bearings are noisy.
    My question is how bad is this issue? Is the gearbox going to grenade eventually and need to be replaced? If so how much am I looking at?
    Will a fluid change help the issue at all?
  4. May 12, 2016 at 2:34 PM
    MrRiverMan
    WNC
    All older w59 transmissions whine in those gears to some degree. Mine started making a loud tapping/clacking noise when I had the bearing failure. I still drove it another 500 miles or so before I pulled the transmission, and it didn't grenade on me. ymmv.
  5. May 12, 2016 at 3:43 PM
    Xyphon112
    Awesome. That was basically my question: how normal is the whine.
  6. Jul 16, 2016 at 9:37 PM
    jrf89
    jrf89 Member
    1999 Tacoma EC 4x4 2.7L 5 speed SR5
    Did you guys have any issues with the counter 5th gear and synchro spacing? For some reason the reverse synchro pull ring is sticking out too far and not letting the counter gear move all the way forward on the shaft. It's a matter of millimeters but has put a halt on my rebuild for 2 days now. I give a more detailed explanation and pictures in this thread https://www.tacomaworld.com/threads/help-getting-w59-transmission-back-together
  7. Jan 17, 2022 at 8:22 AM
    Ikeatlien
    Ikeatlien Active Member
    2003 tacoma regular cab 4x4
    Dos this ever get solved?
  8. Jan 19, 2022 at 6:59 PM
    jekerskel
    jekerskel Well-Known Member
    Zach
    Bellingham WA
    2004 SR5 Extended cab 2wd 5 speed
    V-LED low and high beam headlights.
    My 04 2wd has a very pronounced whine in neutral. Can hear it in 1st and 2nd and it seems to be gone on the others. I recently drained clean fluid out and replaced with redline. Seemed to help some but this thing will have to be fixed or replaced at some point. Curious what bearing is bad tho that can o my be heard in the 1st two gears.
  9. Jan 22, 2022 at 5:53 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Just want to clarify that replacing the throw-out bearing doesn't require a transmission rebuild. You just have to back it off and get behind the bellhousing where the clutch & flywheel are- it's a good thing to replace as well (along with the pilot bearing) whenever doing the clutch.
    I assume that's what you were getting at anyways, but removing & rebuilding a trans is definitely much more involved than just backing it off to replace clutch components.
    Currygoat[QUOTED] likes this.
