Trans. Output shaft seal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Graybeard69, Jan 16, 2020.
  1. Jan 16, 2020 at 8:42 AM
    Graybeard69
    Graybeard69 [OP] Member
    Dave
    2016 Tacoma
    I've got a 2016 Tacoma with 43k miles and I'm on my second output shaft seal. Is anyone else having any issues?
  2. Jan 16, 2020 at 9:07 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Need a little more info. Auto, or Manual? 2wd, or 4wd?
  3. Jan 16, 2020 at 9:19 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    howd you come to find problems with the seal?
  4. Jan 16, 2020 at 9:32 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Probably AT. Probably a bushing or out of round issue, pure speculation. Certainly is not a commom Tacoma issue.
    Chew likes this.
  5. Jan 16, 2020 at 9:47 AM
    Graybeard69
    Dave
    2016 Tacoma
    Sorry, 2wd automatic. The ATF leaking was the giveaway that I have an issue. First seal want bad just before 42K, second seal started leaking just over 1k later.
  6. Jan 16, 2020 at 9:48 AM
    fiftyxp
    so soon makes me think they did a bad job on the replacement.
  7. Jan 16, 2020 at 9:55 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    71K on my 4WD 2016. All's dry.
    G.
  8. Jan 16, 2020 at 9:58 AM
    na8rboy
    WI
    This, and/or they didn't check driveshaft for any defects, which caused first failure.
    SR-71A, Superdave1.0, Chew and 4 others like this.
  9. Jan 16, 2020 at 10:00 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    That's where I am coming from.
    fiftyxp likes this.
  10. Jan 16, 2020 at 10:02 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    No Nick's in the polished shaft?
    Chew likes this.
  11. Jan 16, 2020 at 11:28 AM
    Graybeard69
    Dave
    2016 Tacoma
    No nicks that I could see. I just bought another seal, and will install it tonight. I'll check and see if there is anything on the driveshaft that could be snagging the seal.
  12. Jan 16, 2020 at 11:29 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Is this a bearing or bushing next to the seal?
  13. Jan 16, 2020 at 3:05 PM
    JustMeMyselfAndI
    JustMeMyselfAndI Member
    Why don't you let Toyota fix it under warranty? US trucks have a 5yr , 60K Mile Powertrain warranty.
  14. Jan 16, 2020 at 3:15 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Like another said should be covered under powertrain warranty.
    Question, was the new seal an OEM toyota seal? Or A/M seal?
  15. Jan 16, 2020 at 3:28 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I know it might sound obvious, but you're greasing the OD and ID of the seal before installing and only "pushing" on the OD of the seal to install right? Sometimes the seal can wear out the shaft, counterintuitively, grit imbeddes in the softer rubber then abraids the shaft, as long as it's still a bright polish on the shaft u should be good.
  16. Jan 16, 2020 at 3:29 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Also, hit the quote button on the bottom right and it'll reply directly to whoever you're talkin to! :thumbsup:
    Chew and ryan760 like this.
  17. Jan 16, 2020 at 3:44 PM
    Graybeard69
    Dave
    2016 Tacoma
    Toyota seal
    Superdave1.0[QUOTED] likes this.
  18. Jan 16, 2020 at 3:48 PM
    Graybeard69
    Dave
    2016 Tacoma
    When I called the dealer, I was told thr seal was not covered under the drivetrain warranty.
    fiftyxp and Superdave1.0 like this.
  19. Jan 16, 2020 at 4:16 PM
    fiftyxp
    Maybe it's not the seal and something else covered under warranty
    Superdave1.0 likes this.
  20. Jan 16, 2020 at 4:26 PM
    Superdave1.0
    SoCal
    Since you are doing the work yourself. When you pull the driveshaft, check the end of driveshaft for smoothness. If there is a burr or rough spot on driveshaft, where it meets the seal, it could cause a leak. Also check the race on the transmission where the seal goes into. That could have an imperfection and cause a leak.
    Anywhere the seal will be touching, that metal needs to be smooth. No indentations or raised areas.
    Chew and na8rboy like this.
