trans problems what to do rebuild or buy used?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sick 3.4 tacoma, Apr 22, 2013.
  1. Apr 22, 2013 at 1:21 PM
    sick 3.4 tacoma
    sick 3.4 tacoma [OP] Well-Known Member
    Eric
    portland Oregon
    2003 double cab 4x4
    elite bumper, xrc8 winch, 12in sub, cb, flowmaster, deck plate mod, 3in lift.
    last week my auto trans started to slip in first gear and only in first i have a couple of options should i replace it or should i try to rebuild it? any advice would be great thanks
  2. Apr 22, 2013 at 3:05 PM
    sick 3.4 tacoma
    Eric
    portland Oregon
    2003 double cab 4x4
    question will an auto trans slip worse in 1st than it would in 4th or is the other way around when they normaly go bad?
  3. Apr 22, 2013 at 3:20 PM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    Take up to Browns Camp and finish it off, THEN rebuild it!
  4. Apr 22, 2013 at 3:31 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    I would have it looked at soon. It may just be a band. But probaly be cheaper now than to trash it completely. Just my .02.
  5. Apr 22, 2013 at 4:09 PM
    sick 3.4 tacoma
    Eric
    portland Oregon
    2003 double cab 4x4
    i think i might just do a rebuild kit on it. plus if i drive like a normal person nice and easy it drives great shifts normal and does not make any noise.
  6. Apr 22, 2013 at 6:27 PM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Might just do a drain and fill and add some lucas tranny additive.
  7. May 6, 2013 at 11:44 AM
    sick 3.4 tacoma
    Eric
    portland Oregon
    2003 double cab 4x4
    quick update i pulled the trans out this weekend and i come to find out that its not the trans i had a broken motor mount that sheard off of the frame and was causing the motor and trans to twist in the motor compartment causing the truck to slip out of gear when i hit the gas. dont worrie all has been welded back together and the truck drives great again :)
