Trans shift issues with p0717 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ricky06, Jul 14, 2025.
  1. Jul 14, 2025 at 6:15 PM
    Ricky06
    Ricky06 [OP] New Member
    Hi,
    My truck was doing just fine then decided to randomly start shifting weird. When I ran the code it says it’s a p0717. I tried filling it and no difference in shifting just spraying out the breather. It’s not overfilled and the trans temp light isn’t coming on so I’m not sure why. I then replaced it the sensor and it’s still throwing the code. I’m hoping it’s not the tcm but any other ideas?
    HondaGM likes this.
  2. Jul 14, 2025 at 6:57 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    P0717 is for the input speed sensor, it sets when there is no signal or an erratic signal from the Turbine Input Speed Sensor on the transmission.
    I would suspect an open or shorted wire between the sensor and ECM.
    What year and engine is your truck?
    HondaGM likes this.
  3. Jul 14, 2025 at 6:58 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW..
  4. Jul 14, 2025 at 6:59 PM
    Ricky06
    It is an 06 with the 4.0. When I replaced the sensor the wiring looked fine.
    HondaGM likes this.
  5. Jul 14, 2025 at 7:01 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    It’s spraying out of the breather?
  6. Jul 14, 2025 at 7:06 PM
    Ricky06
    I’m not exactly sure why it’s now deciding to after I added fluid. It’s hard to over fill a transmission that uses a fill plug.
    HondaGM[QUOTED] likes this.
  7. Jul 14, 2025 at 7:10 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you examine the whole harness though, you have to remember the wiring goes all the way from the sensor, over the transmission, behind the engine, and around through the firewall to the ECM behind the glovebox.
    You need an oscilloscope to check the signal but you can ohm check the wires and do a visual inspection of the harness.
    HondaGM likes this.
  8. Jul 14, 2025 at 7:13 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If you filled it to the bottom of the fill plug it's way overfilled, the check plug is on the bottom of the pan. Engine must be running in park, trans temp 97-115F to check.
