trans slipping?
Discussion in 'Technical Chat' started by skipster01, Nov 18, 2009.
  1. Nov 18, 2009 at 5:42 AM
    skipster01
    skipster01 [OP] Member
    Iowa
    Tacoma ext cab SR5
    3-4 inch lift, 17"rims procomp tires
    have a 1995½ tacoma 3.4 engine with 5speed trans. It slips in 3rd and 4th. Just after you let the clutch out. then it doesn't slip.
    The clutch has 70k on it and suprises me that it would go out this soon. I have personally babied the clutch since I have owned it. Before the clutch got replaced the first time, there was a continuous squeak in the transmission at idle not moving when the clutch was released. When you barely push on the clutch, the squeek went away. well, that squeak came back at about 50k on the clutch that is on now and currently 70k now.
    I have read a few threads about the transfer case stuck in Neutral. I don't understand what that would mean. I have checked by putting the truck in 4wd and the truck doesn't slip. Ideas? suggestions, or causes?
    skip:eek:
  2. Nov 18, 2009 at 5:49 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The squeak sounds like the throw-out bearing is going. Did you replace the clutch with a kit? What brand/type?
  3. Nov 18, 2009 at 5:52 AM
    skipster01
    Iowa
    Tacoma ext cab SR5
    well, had a garage replace the throwout bearing, i'm pretty sure they replaced it, cause I was concerned about it then, now it's back. what would cause that squeak to come back so soon?
  4. Nov 18, 2009 at 5:58 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Cheap parts or abuse. And it sounds like you do not abuse it so I am inclined to say they may have used some cheaper (less quality) parts.
  5. Nov 18, 2009 at 6:28 PM
    Terrier
    Terrier Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    Are you saying that your clutch was replaced 70k ago?
  6. Nov 18, 2009 at 6:31 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    my cousin had the same thing done to his ranger, the berring went out, sorry man
  7. Nov 19, 2009 at 5:28 AM
    skipster01
    Iowa
    Tacoma ext cab SR5
    Yes, the clutch has 70k on it, the truck has 170,000 miles on it now, a garage fixed it the first time. now seems to be going out again. this time it is slipping. there has to be another cause to this problem.
  8. Nov 19, 2009 at 5:30 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Did they resurface the flywheel?
  9. Nov 19, 2009 at 6:23 AM
    skipster01
    Iowa
    Tacoma ext cab SR5
    nope, dont' think they did that, pretty much did basic install, and throwout bearing
