Trans & Tcase Breathers (factory)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FL4x4Taco, Jun 27, 2009.
  1. Jun 27, 2009 at 1:26 PM
    FL4x4Taco
    FL4x4Taco [OP] Well-Known Member
    Today I spent some time looking at the Tcase & Auto trans breather. I found the trans one. There is a nipple coming off the top of the trans, and it runs as a metal line forward for about 12" and transitions into rubber hose that goes to a odd looking breather that is bolted on the back of the driver side cylinder head. As for the Tcase I saw 2 small vacuum lines coming off the top that Y'd into 1 small vacuum line and it ran forward to the top of the bell housing and I couldn't it anymore. Does anyone know if that's the Tcase vent and where does it go?
  2. Jun 28, 2009 at 8:27 AM
    FL4x4Taco
    nobody?
  3. Jun 28, 2009 at 8:45 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    To my knowledge the both run up under the hood next to the front drivers side fender. Thats on second Gens.
  4. Jun 28, 2009 at 9:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct.
  5. Jun 28, 2009 at 9:56 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Well thank you sir for verifying. My mind is sometimes like swiss cheese.
  6. Jun 28, 2009 at 9:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, cant be any worse than mine. :eek:
  7. Jun 28, 2009 at 10:00 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Probably not you have 20k post to remember bits and pieces of!
  8. Jun 28, 2009 at 10:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I know..:(
  9. Jun 28, 2009 at 10:22 AM
    jandrews
    '09 FourDubDee TRD OR
    Is the front diff breather relocated from factory? I picked up stuff at Lowes yesterday to relocate 3 diffs if need be, but if the only one that needs moving is the rear, that'd save me some time.
  10. Jun 28, 2009 at 3:01 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I'd love to know if the front even has a breather. I can't find it.
  11. Jun 28, 2009 at 4:48 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    You need only do the rear as the others are in the engine compartment.
  12. Jun 29, 2009 at 3:59 AM
    FL4x4Taco
    so the Tcase is the 2nd smaller vent on the drivers fender?
  13. Jun 29, 2009 at 12:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I just went take it all apart. The two line together are for the front diff. The large line goes to the diff and the small one goes to my actuator. The trans line runs up to the housing on the trans and stops there doesn't come all the way up just part of the way.
  14. Jun 29, 2009 at 12:52 PM
    FL4x4Taco
    Luk8272- This brings me back to my original Q. Where is the Tcase vented?
  15. Jun 29, 2009 at 1:05 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Ok just went back out. It is tied or clamped next to the trans breather. Located at the housing of the transmission.
    Recap:
    The two lines near the drivers fender are the Front diff(Larger) and Actuator(Small)
    Near transmission housing is the Trans breather(Large) and the Transfercase breather(Small).
  16. Jun 29, 2009 at 1:29 PM
    FL4x4Taco
    Luk- could the small line coming off the Tcase be from the actuator?
  17. Jun 29, 2009 at 1:34 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I am not understanding your question.
    Are you saying that the line coming off of the transfer case ties into the front diff actuator?
    Each line is seperate. The trans line doesn't tie into any other lines, it is just clamped next to the Tcas, as the actuator and front diff lines are seperate and clamped together.
    If that is not what you are saying you can pm me to explain better if you don't wish to do so on the thread. I can check on my truck as you ask.
  18. Jun 29, 2009 at 2:19 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Here is what we have figured out, for those looking later.
    The actuator for the Tcase has a line running into the Tcase. The Tcase has 2 lines comming out that "Y" into 1 then follows the Transmission breather line to the transmission housing where the are both clamped.
    The front differential and Diff actuator run up to the drivers side fender.
    The rear diff breather is on the top drivers side of the diff. (Not exteded from factory)
  19. Jun 29, 2009 at 2:28 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    I didn't think you liked the Swiss?
  20. Jun 29, 2009 at 2:35 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I can never find those threads when I need them. But hey I learn better by going out there and seeing for myself anyways. Now I won't likely forget.
