Trans & Tcase Breathers (factory)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FL4x4Taco, Jun 27, 2009.
  1. Jun 29, 2009 at 2:38 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I don't think extending those would be too difficult. I unplugged them and pulled them under the truck. All you would need, would be the proper sized fittings and extra hose, you could reuse the breathers. But like previously stated if the water is that high I have other problems.
  2. Jun 29, 2009 at 2:44 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I climbed in through the engine. I'm 5'7" and about 150lbs. Like a spider monkey.
  3. Jun 29, 2009 at 3:01 PM
    FL4x4Taco
    FL4x4Taco [OP] Well-Known Member
    I had trouble getting my hands up in the bell housing area. I did it with the truck stone cold on a Sat morning. I never did see what happens to the Tcase vant. Last I chacked it's near the bell housing. I might try again and give everything a look over. Thanks for everyone putting their 2 cents in. We actually got somewhere. So the only vent that really needs mod'd is the rear.
  4. Jun 29, 2009 at 3:10 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Thats what I did. Cost less than $6.
