Trans Temp Gauge???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by A_Ninja_Racer, Aug 28, 2011.
  1. Aug 28, 2011 at 2:30 PM
    A_Ninja_Racer
    A_Ninja_Racer [OP] Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Has anyone installed a Trans Temp Gauge into there V6 Auto Transmissions yet. My Question Is: Is there a fitting or bolt that you just replace with the temp sending unit or did you have to drill and tap something? I do the occasional Hauling and think it would be nice to monitor the the Trans temp.
  2. Aug 28, 2011 at 2:31 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    itll probably read straight from the ECU instead of being bugged in
  3. Aug 28, 2011 at 2:38 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Pretty sure the ECU doesn't read tranny temp. Or else this would be as easy as getting an ultragauge.
  4. Aug 28, 2011 at 2:49 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    You may be able to install a T between the Trany. and the cooler.
  5. Aug 28, 2011 at 2:50 PM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  6. Aug 28, 2011 at 2:55 PM
    A_Ninja_Racer
    Tampa, FL
    All of the temp gauges are coming with temp sensors that look like they bolt into the side of the trany but none of them provide vehical specific instructions.
  7. Aug 28, 2011 at 2:56 PM
    08pretaco
    Oliver
    az
    ahh yes, forgot those don't come up on the list for the 2 gauges....so ya I read in to the FJ link, looks like fun project!
