Transfer and differential fluid change ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GOTSAND?18, Aug 5, 2021.
  1. Aug 5, 2021 at 2:55 PM
    GOTSAND?18
    GOTSAND?18 [OP] Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    It’s probably been brought up a few times . What mileage do the fluids need to be changed . Per the manual says 15k but reading on here most people change at 30k ?
  2. Aug 5, 2021 at 2:58 PM
    SLeeper512
    SLeeper512 Well-Known Member
    Sam
    2021 SR5 DCLB Tacoma white with red topper with tow pkg
    If you regear they will say 15k. Tacoma now says 30k.
    I just did mine at 20k and it was very black, with lots of extremely fine shavings on the magnetic plugs. Will keep doing at 20k at least for next change or two.
    Some people never changed theirs... but I would not recommend that.
    p.s. It took more than I thought... and I didn't spill much :)
  3. Aug 5, 2021 at 3:01 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I changed both my front and rear diffs at 800 miles and replaced with Redline oil.
    I found the rear diff on my 2018 under filled.
    SLeeper512 and Tacospike like this.
  4. Aug 5, 2021 at 3:04 PM
    Tacospike
    Two Trucks
    I replaced at 48k and was still an amber color. Used Redline
  5. Aug 5, 2021 at 3:07 PM
    Fohu
    Fohu Well-Known Member
    Glade park Colorado
    2019 trd or access cab
    I’m about to do mine this weekend with amsoil and I’m at 36000
  6. Aug 5, 2021 at 6:11 PM
    gavia
    gavia Well-Known Member
    19 2.7L 4x4 BWCA Edition
    the manual says inspect at 18K for the diffs - I just change mine at 20K intervals. Easy and cheap, so why not. I'm not sure about the transfer case, but I think the manual says to inspect or something at 40K - I just did mine at 50K. Used Redline MT-LV... again, this is easy and cheap, so why not.
    ndoldman59, SLeeper512 and ernscott like this.
