Transfer Case Actuator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skybolt, Feb 28, 2017.
  1. Feb 28, 2017 at 12:06 PM
    skybolt
    skybolt [OP] Active Member
    Just a heads up so you can watch out for this problem.
    I purchased a 2017 TRD off road 4x4 access cab with premium and tow package with Quicksand paint. Cat help but love this truck.
    Problem is I have only driven it 465 Miles and now it's in the service department as it won't come out of 4Lo.
    Picked it up Sunday, drove around Monday, drove to work Tuesday and took it up a dirt road in 4Hi and down again. All fine. Wednesday at lunch took it up a hill in crawl and at the top tried to get it back to 4Hi or 2wd. No go. Flatbed to dealer.
    That was last week and I'm still waiting for answers. I'm told the transfer case will need to be split and a new actuator installed. It was an electronic failure, I was told.
    Is this right? Why so new and a problem, any one else had this happen?
  2. Feb 28, 2017 at 12:26 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    You aren't the first to have this problem. Others with similar experiences had the same diagnosis. Doesn't seem too common but looks like you just got unlucky.
    There are a small amount of bad parts in every production run, that's what the warranty is for. At least it is a problem that is easy to diagnose and fix.
  3. Feb 28, 2017 at 1:00 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    Geez you really have to split open the transfer case to replace the shift actuator?
  4. Feb 28, 2017 at 1:44 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    The way i see it, the more things go wrong the more fixes/tsbs/recalls. So i thankyou. My 16 has/had its fair share of issues. The more we complain and take it to get work done the more benefit for future taco owners. Would be nice to not have issues . But its the way she goes.
    shakerhood likes this.
  5. Feb 28, 2017 at 3:57 PM
    skybolt
    Just got off the phone and the part has not yet arrived but should be in today or tomorrow.
    The best news was I finally got the process info for the repair. It will not be as involved as I first thought, read, or assumed. It is an electronic actuator on the back of the transfer case and will only need to be removed and replaced. No removal of the transfer case and no opening of it either.
    For the past week I've been dreading the repair, mainly because no one supplied the information from any of Toyota's personal. Finally today the Assistant Service Manager led me through the process. When the part does arrive the old one will be removed, the new one bolted on and then tested. This should take about three hours from the time the part comes in. The longest part of the process is waiting for the part to arrive.
    vinkon235 likes this.
  6. Feb 28, 2017 at 6:23 PM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    My prediction is that a lot of us are going to be doing this after warranty runs out. An electric motor and associated solder/contacts in that location is just asking for long term issues after enough miles of vibration, wet, and cold. The good news is it's an easy DIY and there will be plenty of junkyard units from other Third Gens (Smittys, the one that got Dukes of Hazzarded by the escaped inmate, etc). I just replaced the actuator stepper motor and computer on the wife's Cayenne. It took 4 hours, and going by the general German-to-Japanese repair shitshow conversion, this means the Tacoma should only take about 45 minutes!
    Big tall dave, 02Duck and 2016/7544G like this.
  7. Mar 1, 2017 at 1:28 PM
    Jaymtb
    Jaymtb Well-Known Member
    Jay
    Colorado Mtns.
    2017 TRD OR AC ARE MX
    This could be a problem in the boonies. Is there a way to manually get it out of low range to avoid a tow? Is anyone familiar with this actuator/motor and how to work it manually?
    Thanks, J
    JETACO likes this.
  8. Mar 1, 2017 at 1:49 PM
    VTDave
    Vermont, USA
    Haven't had to do it - not even on my '05. An idea: tap the actuator with a hammer, like you would a failing starter motor, and then apply power directly using a battery. Next get back home and work on your real repair.
    Big tall dave likes this.
  9. Mar 1, 2017 at 2:36 PM
    thdrduck
    thdrduck Well-Known Member
    Sure do miss the second lever. Stupid buttons.
  10. Mar 1, 2017 at 3:37 PM
    cascadetaco
    central oregon
    Totally agree...buttons stupid. Had issues w/actuators on gm trucks I have had too.
  11. Mar 1, 2017 at 3:42 PM
    Jaymtb
    Jay
    Colorado Mtns.
    The trick is just where to check for power- or apply power in that bunch of wires, in case you just lost a switch- or how to manually move the servo actuator- anyone had this apart?
  12. Mar 1, 2017 at 3:48 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    My actuator went out after about a month after buying the truck. Took about 2 weeks to get the parts. The transfer case does come apart but it's not that bad. Works great now. Covered under warranty....
    Derek17Trd4x4 likes this.
  13. Mar 1, 2017 at 4:15 PM
    skybolt
    I told Toyota corporate that there should be a way to manually shift all components if the electronics fail. If, or when, this happens outside of warranty I will surely find out, if not sooner. What was wrong with mechanical levers?
    I used to spend months at a time doing exploration work in Australia and we relied on our Toyota Land Cruisers and sometimes we used a Hilux, but not for extended work. I would do repairs in the field but if now days if an electrical component goes out and you don't have a spare one would be SOL. There are ways I have seen of moving some components but that was on an earlier model. For my 2017 I have only driven it for a few days and am not that familiar with all the workings. Does anyone have detailed diagrams of the transfer case and other mechanicals as factory workshop manuals are too hard to find?
  14. Mar 1, 2017 at 4:21 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Eliminating Levers has got to be financially related, I would much rather have a mechanical lever over switches!
  15. Mar 2, 2017 at 5:13 AM
    thdrduck
    No way is a button cheaper then a lever. Keyless entry, keyless ignition, very George Jettson but not cheaper.
  16. Mar 2, 2017 at 9:15 AM
    shakerhood
    Southern Ohio
    They follow Kaizen and each Action Work Out is to make it cheaper, eliminate weight, parts reduction, and faster cycle time. The switch may be a few pennies more but weighs less, uses fewer parts, and speeds up the assembly process, so yes Cheaper.
    jrain904 likes this.
  17. Mar 2, 2017 at 1:14 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    I asked the Toyota mechanic that replaced my actuator that very question.
    He said most people want a button to push, not levers to move....Beats me, I like the levers.
  18. Mar 2, 2017 at 1:31 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I was told it has to do with interior design. Being forced to work around the shifters is limiting for them. Probably also has to do with speeding up assembly, too. I dunno, I wish trucks were just trucks again, mechanical levers and actuator with just enough technology so I don't get bored listening to tires humming.
    KY_Rob, 02Duck, DJB1 and 2 others like this.
  19. Mar 2, 2017 at 1:37 PM
    shakerhood
    Southern Ohio
    It keeps getting worse too, the trend now on Automatic equipped Vehicles is doing away with the shifter and going with a Dial or a couple Buttons, seems like a bad idea.
    ABA180 and Riding Dirty like this.
  20. Mar 2, 2017 at 1:45 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    What else would he say? Asking a mechanic a question for an engineer and a CFO.
