Transfer case Actuator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dragon egg29, Oct 21, 2024.
  1. Oct 21, 2024 at 6:50 PM
    Dragon egg29
    Dragon egg29 [OP] Member
    2016 Toyota Tacoma
    Winch, Light bar and Pod lights
    I recently had some issues with what I initially believed to be my transfer case actuator. I bought a replacement off of parts geek which was confirmed to be the same part as what the dealership sells by a parts person. The problem being that the replacement when installed or just plugged in because it's a pain to switch back and forth, throws abs and traction control codes along with 2 wheel to 4 wheel change failed where as the old one would only show the change failed when attempting to change over. I currently have the old actuator in it and the change failed light isn't showing and my next step was to change the actuator on the front diff. I'm just curious about the cause of that should I need to change the transferase actuator too.
  2. Oct 22, 2024 at 3:55 AM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    No idea if this is your issue, but I believe it’s the T case actuator that has to be “timed” properly to allow it to work. The truck computers have to get the proper position indication from the actuator for everything to work well.
    There are threads here that cover it in precise detail. I believe one of the members in that is @BigWhiteTRD
    Might try searching for that screen name, good luck.
    gudujarlson, Paddyd and Chew like this.
  3. Oct 22, 2024 at 12:00 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I heard timing it is a PITA. Best to watch a video or two on YouTube.
  4. Oct 22, 2024 at 5:25 PM
    Dragon egg29
    2016 Toyota Tacoma
    I did watch a YouTube video of someone taking their t case actuator off and re installing it. they explained how to set the gears back properly which was actually only one of the 3 gears that needed to be set specifically. I'll link it here. however if there's a different type of "timing" you're referring to then please let me know. https://youtu.be/GCY2BCdlU4I?si=wiW0Nm0AikRd8Tz5 this is the video I initially watched to take the old one off and put the new one on.
  5. Oct 23, 2024 at 6:12 AM
    PTPinETN
    Alan
    ETN
    That’s what I was referring to. Thanks for the link, good video.
  6. Oct 24, 2024 at 3:15 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    The front actuator (ADD), you have to make sure the replacement actuator isn't too far in either direction (engaged or disengaged), but any mid position is fine.
    The transfer case actuator has to be carefully timed, as linked in this thread.
