Transfer Case Breather venting into cabin
Discussion in '1st Gen. Tacomas (1995-2004)' started by Seventh, Jan 12, 2013.
  1. Jan 12, 2013 at 1:39 PM
    Seventh
    Seventh [OP] Insert witty title here
    Boston, MA
    2001 Reg Cab 4x4
    Aah, the joys of an old truck. My '01 was seriously neglected by it's former owner, so each part that I take off is like a cornucopia of completely rusted out bits... Anyway, I'd been faintly smelling oil/grease in my cab for a while, especially with the windows open. I googled like mad and found this thread on TTORA:
    http://www.ttora.com/forum/showthread.php?t=53260
    Particularly this bit:
    So I popped off the plastic bits and this is what I found. Yikes.
    Edit: Does anyone also know the proper name for this part? ^^ Searching around gets me a lot of people looking to replace the actual shift boot, but not this cover/gasket.
    I'm pretty sure that this might be the root cause of my problem. There's nothing leaking up there, but plenty of old oil and my breathers look to be in terrible shape. (Assuming they are where I think they are - just in front of each shifter, right?) The gasket under the shift boot is actually in decent condition but I'm going to replace it anyway.
    How hard is it to replace these two breathers? I'm relatively mechanically inclined but when it comes to the transmission I really don't want to risk screwing anything up. I figure while I'm at it I'd relocate those breather exit points somewhere else.
    Also, does anyone know what these plastic clips are actually called? They're what the shift boot plate actually screws into, and two of mine are broken. I'd like to get some new ones but I've no idea what they are called.
  2. Jan 12, 2013 at 2:06 PM
    Seventh
    Boston, MA
    2001 Reg Cab 4x4
    In case it helps someone else who finds this thread - turns out the rusty as hell retainer in my second pic is called a "Shift lever boot retainer".
  3. Jan 13, 2013 at 8:33 AM
    Seventh
    Boston, MA
    2001 Reg Cab 4x4
    Nobody on the breathers/clip part #? :(
  4. Jan 13, 2013 at 10:41 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    As far as the two breathers, IIRC, all you have to do is full the little cylindrical caps off, revealing a nipple, and you just need some rubber tubing and home hose clamps and you can route the vents elsewhere.
  5. Jan 13, 2013 at 11:27 AM
    Seventh
    Boston, MA
    2001 Reg Cab 4x4
    Thanks! I gave the caps a tug and they didn't seem to want to come off - mine are pretty gummed up. Do they unscrew, or just pull off?
    Also, hopefully this will help anyone finding this thread - if your plastic clips for the shift lever boot retainer are busted, these 5/16" #18 speed nuts at Home Depot are a perfect fit. They slide right over the body panel and line up exactly where the screw comes in. I needed to drill out the covers slightly to get the screws in but other than that it's a 2 minute job that you can do from inside the cab. (I completely forgot to take a picture on the truck, but trust me - if you break your clips, these are what you want).
  6. Jan 13, 2013 at 12:43 PM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2007 DCSB SR5 4X4
    Take a look at this link. Look at post 4. You will see what those breathers look like.
    Breather Link
  7. Jan 13, 2013 at 6:02 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I was able to pull one off and it was a battle.
    Also, if you search for the rear diff breather mod on this forum and see what they use for that, there is a screw in union you can order from toyota to replace the breathers all together and run some hoses.
