Transfer case differences between an auto and a 6-speed tranny?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2005 Taco 4x4, Nov 16, 2024.
  1. Nov 16, 2024 at 7:57 PM
    2005 Taco 4x4
    2005 Taco 4x4 [OP] Active Member
    Looking to purchase a used TC for my 6-speed manual 2005 Taco down the road. Does anyone happen to know if both tranny shares the same TC or does each tranny use a different TC?
    A TW member mentioned that the spline count on the output shaft may be different?
    Any knowledge is appreciated.
    Thank you y'all!
  2. Nov 16, 2024 at 8:01 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Need to get one from a manual or plan on disassembly to swap the input. The automatics and manuals use different spline counts and then the autos use a coupler sleeve to adapt to the male output of the auto trans.
  3. Nov 16, 2024 at 8:11 PM
    2005 Taco 4x4
    Thank you!
  4. Nov 17, 2024 at 12:13 PM
    2005 Taco 4x4
    I'll ask it here too as I'm hoping to get more info and knowledge needed for my future TC swap project.
    Does any of you know how many other Toyota models share the same exact TC with the Gen 2 Taco? Tundra? 4Runner? Lexus??
    Just in case I want to do a direct swap without any mods, disassembly and/or add additional parts to make it work.
    So few used 6-speed TC out there that the more available options from other models for a direct swap, the better. As long as it works, I don't really care if the 6-speed manual TC comes from a Tundra, Lexus, etc. I know the 6-speed Gen 2 Taco is rare but it's probably even more rare to find a 6-speed Tundra, 4Runner, etc., that shares the same exact TC.
    Thanks!
