Transfer Case Drain & Fill Plugs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CJWinOR, Dec 7, 2024.
  1. Dec 7, 2024 at 8:46 PM
    CJWinOR
    CJWinOR [OP] Member
    I've read a bewildering number of postings about part numbers for drain plugs, with and without magnets. I'm clear about the differential part numbers, but unclear about transfer case drain and fill plug part numbers. I'd appreciate some help with the numbers please.
  2. Dec 7, 2024 at 8:57 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    There should be no reason to need or change T-Case drain and fill plugs. 24mm socket. Did you lose the plugs or something?
  3. Dec 7, 2024 at 9:02 PM
    CJWinOR
    CJWinOR [OP] Member
    I just want them in case I need one. It is a long way to a dealership and I don't want to need to rent a car to get to one if I need to replace one for some reason.
  4. Dec 7, 2024 at 9:15 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Just crack each loose beforehand and then tighten them back up until you’re ready to do the job?
    Should be 0 reason you need extra or replacements of either of them, they aren’t 10mm allens, so no one has problems with them.
    Not trying to belittle the question or concern, but I really see no reason to buy extras. They come right out with a 24mm.
    Superdave1.0 likes this.
  5. Dec 7, 2024 at 9:31 PM
    Superdave1.0
    SoCal
    I promise you will never need one. I work on 20+ year old Tacomas almost weekly. Worked on a 1996 today. If you need a T case drain plug then you need to step away from the wrench, and let someone else service your truck. They don't wear out or strip ever.
  6. Dec 7, 2024 at 9:44 PM
    Bishop84
    Bishop84 Well-Known Member
    In the salt areas on the 1st gens they fuse to the gasket and the tcase.
    I can usually save them. It's the allen key front diff thats the big bastard. I still rarely change them.
    Just need gaskets, crack both, if one is fubar, just retighten and buy it.
    BillF1564 and Superdave1.0 like this.
  7. Dec 7, 2024 at 9:55 PM
    Superdave1.0
    SoCal
    Count me spoiled working in SoCal. If your T-case drain plug is rust welded on, you likely have much bigger problems waiting for you.
    BillF1564 likes this.
  8. Dec 7, 2024 at 9:59 PM
    Bishop84
    I've started charging more for rust buckets. Sometimes 1-2 hours more for even simple stuff.
    To be fair though, we don't have bugs and I've seen California a few times. I'd melt. The coast is nice but I'd be living in a cardboard box.
