Transfer case fluid option?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RDW59565, Sep 4, 2021.
  1. Sep 4, 2021 at 6:37 PM
    RDW59565
    RDW59565 [OP] Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
  2. Sep 4, 2021 at 9:36 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I use liqui moly in the wife’s Macan. It’s a pretty good German brand of oil and I’d have no concerns with it.
  3. Sep 4, 2021 at 9:39 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  4. Sep 5, 2021 at 7:25 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    usmc2msu likes this.
  5. Sep 5, 2021 at 7:31 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Check your Owner's Manual for correct viscosity and specification.
    Some require the 75w GL-5 specification.
  6. Sep 5, 2021 at 7:40 AM
    RDW59565
    Utah
    Good point!
  7. Sep 5, 2021 at 7:44 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It will probably work if your region doesn't see much subzero temps. Viscosity at 40C is very similar, 33 Cst vs 31 Cst. Viscosity at -40C is two and half times that of Red Line MT-LV. There's a partial overlap in OEM specs the two oils are claimed to satisfy:
    https://pim.liqui-moly.de/pidoc/P004182/20842-TopTecMTF5100SAE75W-24.0-us.pdf
    https://www.redlineoil.com/Content/files/tech/MT-LV_GO_PROD_INFO_2021.pdf
  8. Sep 5, 2021 at 7:50 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3rd gens call for a special Toyota-branded low-viscosity gear oil in the T-case. The automatically generated Amazon link at the bottom of this page has it listed at $80.58 a can. Straight 75W90 GL5 has been reported to cause 2WD/4WD shifting problems, as discussed here: https://www.tacomaworld.com/threads/‘16-newer-transfer-cases.636057/
  9. Feb 5, 2022 at 3:34 PM
    Menjivar54
    Menjivar54 Well-Known Member
    2020 TRD PRO
    Did you end up using the Liqui Moly? I want to change my fluid and wanted to know if anyone else has used this. I plan on using the Liqui Moly 75w90 for the trans and diffs
  10. Feb 5, 2022 at 4:05 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The Redline equivalent to LiquiMoly 5100 appears to be Redline DCTF(dual clutch transmission fluid).
  11. Feb 24, 2022 at 12:10 PM
    Nitesmoke
    Nitesmoke Member
    Kennesaw, GA
    2017 Tacoma TRD OR DCSB 4x4 MT
    Stock
    Not sure if anyone else saw this yet, but I’ve been looking into an alternative to the Genuine Toyota 75W LF transfer case fluid. This Redline claims to be one. https://www.redlineoil.com/mt-lv-70w75w
  12. Feb 24, 2022 at 1:12 PM
    kapn
    kapn Well-Known Member
    Annapolis, MD
    2016 TRDORLB Blue
    I've used the Redline https://www.redlineoil.com/mt-lv-70w75w for 25k miles now in my Tacoma Transfer case. Not a long time to tell the difference but I had been using Redline oils in transmissions on my previous Saabs for a combined 300,000+ miles. Saab manual transmissions weren't known for longevity and I got 270k miles out of one by using Redline MTL and 90k out of another before selling them.
  13. Feb 21, 2025 at 4:23 PM
    strobe
    strobe Member
    Justin
    3rd gen Sport MT
    bumping this - has anyone tried it? On Liqui Moly site it now shows Toyota 08885-81081, which is the toyota t-case oil.
    I would just go with the MT-LV, but it comes in quarts... the transfer case just happens to call for 1 Liter. Makes the price difference $18 vs $46 without having to use 90% of the 2nd redline bottle. The US not using the metric system is so obnoxious.
  14. Feb 21, 2025 at 4:35 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Toss 53ml of the old in with the new.
    Your truck will never know it happened... Ever.
  15. Feb 21, 2025 at 4:51 PM
    DTaco18
    This^^. I bought 2 quarts of MT-LV, but if I was worried about the extra $23 then I'd just buy 1 quart and add a little of the old oil back in.
    I drained the OEM fluid, pumped some MT-LV in, then drained again to flush out the rest of the old stuff.
    Put 1.1-ish quarts in and now I have about a 1/2 quart left over, and I'll only need to buy 1 quart next time... Don't feel like it was a waste.
  16. Feb 21, 2025 at 5:24 PM
    strobe
    strobe Member
    Justin
    3rd gen Sport MT
    I'm leaning towards trying the Liqui Moly, them listing the toyota part # on their site is giving me some confidence. They also have a new GL4 75W-90 I can use for my transmission instead of the redline MT90. I've used MT90 in previous vehicles and know it's good stuff no argument there, just looking at cost here.
    3L of the Liqui Moly 5400 75W-90 + 1L of the 5100 75W totals to $72 shipped... vs redline would be $92 going with just 1QT of the MT-LV, $115 if I got two.
  17. Feb 21, 2025 at 5:41 PM
    strobe
    strobe Member
    Justin
    3rd gen Sport MT
    I guess the liqui moly 5100 is actually only $16 msrp. This is looking like the best combo now :spending:
  18. Feb 21, 2025 at 5:50 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  19. Feb 21, 2025 at 5:57 PM
    strobe
    strobe Member
    Justin
    3rd gen Sport MT
  20. Feb 21, 2025 at 6:20 PM
    TA2016
    Oregon
    I can understand if someone might be on a tight budget and needs to look for less expensive options. I can afford OEM and my truck deserves it.
