Transfer case fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scotland69, Feb 22, 2019.
  1. Sep 19, 2023 at 9:30 PM
    #141
    TX_Tacos05
    TX_Tacos05 New Member
    I just wanted to throw this out there in case anyone wanted some piece of mind on whether they absolutely had to use 75w vs 75w-90. From what I’ve been able to find online, tacomas older than 2015 use 75w-90 in the t-case, where as 2016 and up call for 75w. Source:https://www.blauparts.com/blog/what...acoma-transfer-case-fluid-specification-guide
    I own a 07 double cab auto short bed. I’ve owned it since 09 and I’ve neglected gear oil changes while being religious about my oil changes. Sometime around 2013 my transmission gave out on me at roughly 130k miles. I’m confident this happened because of me towing well beyond anything the truck was rated for. I found a used transmission from a local junk yard and did the swap myself. This was the first time I also changed the gear fluids from the t-case and the rear diff. I didn’t change the front diff oil. Being young, dumb, and poor I used the absolute cheapest synthetic 75w-90 I could find which happened to be the bottom shelf O’reillys MasterPro brand. My truck has 284k miles now and until this past weekend was still running on the original oil in the front diff and is still running on the MasterPro 75w-90 in the t-case and rear diff from when I last changed it at 130k(ish) miles. It’s only because I had to swap out a cv axle and lost a bit fluid from the front diff that I decided to change the oil. I’ll going with full synthetic valvoline 75w-90 from Walmart this go around. My truck mostly just sits parked now that I work from home, but the miles it has have mostly been with a boat hooked to the hitch making 9 hour round trips from Austin to the Tx Coast. The more abuse the truck takes, the more I love it. I am however trying to do better with the maintenance, hence me “researching” oils and thus this post. All that to say, you guys who are doing regular maintenance on your truck shouldn’t be overly concerned on whether you’re using Toyotas 75w or any brand of synthetic 75w-90, in my opinion.
    1776Taco likes this.
  2. Sep 20, 2023 at 3:38 AM
    #142
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    I think a lot of people are putting a little to much thought into this. My dad has several F350 dump trucks he bought new in 96, one has 160k the other has 350k, they both have never had gear oil changed. Personally, I don’t see the need to change diff oils less than 100k increments unless they get submerged while off-road. Basic daily driving, I just don’t see it.
    SmoPo16 and Speedbird like this.
  3. Sep 28, 2023 at 8:28 AM
    #143
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
  4. Sep 28, 2023 at 7:57 PM
    #144
    5Sport
    5Sport Well-Known Member
    Can't speak for Ravenol but I use Redline. Been using it my cars for years. No issues. My .02
    oconnor likes this.
  5. Sep 28, 2023 at 8:13 PM
    #145
    dentedporsche
    dentedporsche Well-Known Member
    Ron
    Also used redline mt-lv ... no issues after 5k on 30k change.
    All diffs and manual trans also changed with redline ... always have had great luck with product.
    oconnor and usmc2msu like this.
  6. Sep 29, 2023 at 6:24 AM
    #146
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    I used Ravenol a few months ago, no weird sounds or grinding noises. I'm 100% confident that *any* 75w oil is good enough, that includes Ravenol. Don't sweat it, just do it.
    Tacowin1013 and Xx_Evilvirus_xX like this.
  7. Sep 29, 2023 at 9:55 AM
    #147
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    Tacowin1013 likes this.
  8. Dec 10, 2023 at 9:48 AM
    #148
    Tacodrew22
    Tacodrew22 Well-Known Member
    Andrew
    Michigan
    2022 Tacoma TRD Off-Road
    OnX Off-Road Trail Guide. I help OnX map and document routes. I get out all across the United States but based in Michigan
    Prepping to do a full fluid change on my 22 taco. I ordered 1 quart of the Toyota transfer case fluid. Specs show 1.1 quarts is the total capacity for the transfer case. My thought was I probably won’t get the full 1.1 quarts to drain. Can anyone speak on if just the 1 quart will do the job? Thanks!
  9. Dec 10, 2023 at 10:20 AM
    #149
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    When I used it, I bought the single quart and it was just enough. You might have to work to get the last bit out of whatever pump container you use to get it in the transfer case.
    Tacodrew22[QUOTED] likes this.
  10. Dec 10, 2023 at 10:40 AM
    #150
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I'd drain the transfer case into a clean container to ensure you can pull a little of the old oil off the top if you need a little bit.
  11. Sep 25, 2024 at 4:12 PM
    #151
    mabajada
    mabajada New Member
    2020 Tacoma Double Cab TRD Sport Premium
    Dealer in VancouverBC Canada quotes $181 (which is 135USD) for 1 liter. It's been on back order all summer and they have no idea when they will get it. I'm going with the Redline MT LV .
    usmc2msu likes this.
  12. Oct 12, 2024 at 7:19 AM
    #152
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Just changed everything last week. Redline all around (except the engine). Works great, seems smoother/quieter.
  13. Oct 12, 2024 at 7:58 AM
    #153
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
  14. Oct 12, 2024 at 8:04 AM
    #154
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Capacity is 1 Liter. Can is 1 Liter. (1 Liter = 1.1 quart). One can is sufficient for a drain and fill
  15. Oct 12, 2024 at 10:10 AM
    #155
    BobsTaco91
    BobsTaco91 Active Member
    2017 TRD Off Road
  16. Oct 12, 2024 at 10:29 AM
    #156
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Amsoil with the squeeze bottles work fantastic.
    BUZZCUT likes this.
  17. Oct 12, 2024 at 10:37 AM
    #157
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I used the Ravenol, it seems to be working just fine. Cool bottle, too, has a pull-out spout that makes it easy to do a fill.
    BobsTaco91 likes this.
  18. Oct 12, 2024 at 10:37 AM
    #158
    BillyE
    BillyE Well-Known Member
    I’m not sure that there’s anything to be gained by selecting one fluid or another. Manual transmissions shift differently with different fluids. I don’t think that’s true for a transfer case.
  19. Oct 17, 2024 at 9:45 AM
    #159
    usmc2msu
    TJ
    2017 SR5
    Someone can correct me, but I think the consensus is that most dealerships are using 75-90 out of the drums.
  20. Oct 17, 2024 at 9:48 AM
    #160
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    Assume dealerships are always lazy shitbags until proven othereise and will never waste a chance to cut corners at every possible opportunity to squeeze every penny out of you, so yes, I think that's a safe assumption.
    Speedbird and usmc2msu[QUOTED] like this.
