Transfer case grind EDIT: front axle grind
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Derk33, Jan 7, 2018.
  1. Jan 8, 2018 at 6:32 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    :popcorn: Curious to see if you have a ton of metal shavings when you change the oil next. I would assume so if your tcase is making that much noise.
  2. Jan 8, 2018 at 6:36 AM
    NeonHeights
    NeonHeights Well-Known Member
    I have had grinding come from my case before, but it turned out to be the actuator making that noise when trying to go into 4LO. It clunks fairly often when engaging 4HI
  3. Jan 8, 2018 at 6:36 AM
    Derk33
    Derk33 [OP] Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    It’s snowing like crazy here today so no new oil for me but I will keep you guys updated, I’ll probably just buy some SuperTech till I get all this figured out. Thanks for all the replies, this site has never let me down :D :thumbsup:
  4. Jan 8, 2018 at 10:18 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Milage difference on the tires. Get a tire depth guage n measure them. Running missmatched tires causes major transfer case issues n faster you go the greater change of gernating the tcases. I have done that in my old k20.
  5. Jan 8, 2018 at 10:23 AM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    N yes drain the oil hold a magnet in the oil coming out.
  6. Jan 8, 2018 at 10:34 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    It is nothing like shifting a bicycle. The chain in the t case does not move from a smaller gear to a larger one or vise versa like a bicycle. That part is done with gears.
  7. Jan 8, 2018 at 11:42 AM
    Derk33
    Derek
    Pennylvania
  8. Jan 8, 2018 at 12:53 PM
    Pigpen
    Dan
    Northwest Montana
    I love learning new shit. Thanks!
  9. Jan 8, 2018 at 9:07 PM
    Derk33
    Derek
    Pennylvania
    So as of today, at 35 degrees outside, my transfer case shifts beautifully, even under slight acceleration.
  10. Jan 8, 2018 at 9:49 PM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    mine does to. Im broke so i have been dealing with it. If i treat it like 4 lo no problems. 2h then put the truck in neutral shift to 4h and no noise. I know this is not right and when i can i will get it fixed. now i want to know how bad my problem is but i bet we are getting the same noise. only when really cold and mine does it when im coasting under 5mph no foot on the gas pedal at all
  11. Jan 8, 2018 at 10:44 PM
    Derk33
    Derek
    Pennylvania
    The only other thing I can think of is as the oil gets cold it contracts and drops below where it needs to be, I need to check and make sure I have enough oil in it soon. If you find anything out please let me know and I’ll be sure to pass on anything I find to you!
  12. Jan 9, 2018 at 7:32 AM
    Trucko
    2005 Tacoma
    My truck is actually in the shop right now they were done with it and I was supposed to pick it up so if they can squeeze it in and check the oil I will keep you in the loop
  13. Jan 9, 2018 at 11:10 AM
    Trucko
    2005 Tacoma
    My mechanic just called me after checking the transfer case oil no metal shavings at all per him it looks perfect and this is a family friend not just a random mechanic. I'm at a complete loss still because I can't replicate this unless we are talking single digits cold and where I live it's not that cold right now
  14. Jan 9, 2018 at 12:12 PM
    Trucko
    2005 Tacoma
    So guys what else could it be what else effects the 4 wheel drive system when it's cold. The noise will not be replicated unless it's single digits cold anything besides that it acts like normal if I lived somewhere hot I would never know there was even a problem
  15. Jan 9, 2018 at 1:16 PM
    #35
    Pigpen
    Dan
    Northwest Montana
    After watching that video, it would make sense that the cold oil is causing a slower shift. The front and rear axles must be a little off sync and the slow shift may be causing the synchronizer to slip and grind.
  16. Jan 9, 2018 at 2:24 PM
    #36
    Trucko
    2005 Tacoma
    so what should i ask of my mechanic to do or check for if no metal. they dont like it when you say you read it on a forum
  17. Jan 9, 2018 at 2:24 PM
    #37
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    That one has me puzzled. Initial thought was tire size. But warner temps should result same outcome.are u running synthetic oils? Colder temps synthetic runs better.
  18. Jan 9, 2018 at 2:29 PM
    #38
    Trucko
    2005 Tacoma
    tires look fine no other issues besides the noise when cold. no idea on the oil. mechanic does it all for me
  19. Jan 9, 2018 at 2:29 PM
    #39
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Wonder if the solenoid is slowly activating because of the cold. I would next check the actuator linkage, check for binding.
  20. Jan 9, 2018 at 2:40 PM
    #40
    Trucko
    2005 Tacoma
    easy way i could check this myself being a noob without going to the shop again
