Transfer case grind EDIT: front axle grind
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Derk33, Jan 7, 2018.
  1. Jan 11, 2018 at 11:03 AM
    #61
    gearcruncher
    Canadain bumper technician
    Are you feeling any grinding when you select 4 low ?
    taco2010trd likes this.
  2. Jan 11, 2018 at 11:18 AM
    #62
    Derk33
    Derk33 [OP] Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    No, only in 4hi but it grinds as soon as I flip the switch. I know it’s not the front diff because there’s time between when it grinds and the 4wd light goes steady
  3. Jan 11, 2018 at 11:28 AM
    #63
    gearcruncher
    Then your issue is with the 2hi - 4 hi synchro
  4. Jan 11, 2018 at 2:35 PM
    #64
    Derk33
    Derek
    Pennylvania
    What do you think caused this? I only have 138,000 miles on the truck. Do you think the GL5 oil messed up the synchro?
  5. Jan 11, 2018 at 3:21 PM
    #65
    gearcruncher
    How long have you been driving with low fluid in the transfer case ?
    Synchronizers cut through the oil . If there is no oil to cut through , they run on a dry shaft
    This issue alone is enough to create a problem
    I suggest some Lubegard . Drain out enough to top it off with this stuff
    http://www.lubegard.com/~/C-197/LUBEGARD+Gear+Fluid+Supplement
    Its top quality and compensates for issues like you are having .
    I wouldnt post about it if it didnt work . That Lubegaurd additive is a lifesaver for a transfer case. Use to only be available to transmission shops but Amazon carries it now . Do yourself a favor and buy a bottle . If I am wrong after you add the bottle , make sure you let me know
  6. Jan 11, 2018 at 3:28 PM
    #66
    Derk33
    Derek
    Pennylvania
    It wasn’t excessively low, maybe a few pumps from a hand pump would fill it up. I’d rather fix the problem than put an additive in to help cover up the problem. Maybe as a temporary fix I’ll try the lubeguard. Do you know of any place I could buy the parts to fix it myself?
  7. Jan 11, 2018 at 3:37 PM
    #67
    gearcruncher
    I would have to take your transfer case all apart and inspect each individual part to tell you how much it would cost to fix .
    You cant visually see inside the transfer case without a complete dissasembly .
    With this said , I could probably guess that the synchromesh for the 4hi application is worn down but that would be a guess .
    Here is an idea
    Gonna send you a parts / price list and you can take a guess at the parts you need .
    Here is the parts list and prices [​IMG]2013 Toyota Tacoma Pickup.pdf
    You can purchase the parts you need from any Toyota dealership as long as you know what you are looking for
  8. Jan 12, 2018 at 5:10 AM
    #68
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I don't believe that is true at all. It is chain driven, but the chain is not moved onto different gears the way a bicycle changes gears.
  9. Jan 12, 2018 at 6:35 AM
    #69
    Pigpen
    Dan
    Northwest Montana
    You are correct. I learned something new in the video that was posted.
  10. Jan 12, 2018 at 11:37 AM
    #70
    Derk33
    Derek
    Pennylvania
    UPDATE: my tcase now grinds on the first shift into 4hi but after that all shifts are smooth. I can’t tell if this is better or worse. It’s going to drop below freezing tonight and I’ll mess with it some more.
  11. Jan 12, 2018 at 9:55 PM
    #71
    Derk33
    Derek
    Pennylvania
    Tonight I played around in the snow some and once again the first time I flip into 4hi it grinds but after that I can’t recreate the noise
  12. Apr 17, 2018 at 9:05 PM
    #72
    Derk33
    Derek
    Pennylvania
    Update: I believe a ran into the problem our manual tranny guys run into. I think the GL5 oil was too slick for the transfer case and reduced shift quality. I just put in some gl4/gl5 rated oil and the grinding is completely gone.
    @Trucko just in case you’re still having problems, this might be something to try
  13. Apr 17, 2018 at 9:50 PM
    #73
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Not sure it matters, are you MT or AT?
    Also, what is GL4 rated oil? I replaced the TC fluid with OEM Toyota from stealership. I still grind.
    I am willing to try GL4 rated oil but have no clue what you are indicating...
    thanks
  14. Apr 17, 2018 at 10:31 PM
    #74
    Derk33
    Derek
    Pennylvania
    The GL rating is just a rating the American Petroleum Institute gives on the additive package in the gear oil itself the higher the rating the more anti wear and extreme pressure additives. But in some cases like our MTs the GL5 decreases shift quality because the oil is essentially too “slick”...I’m unsure of he science behind it... and I assume that’s the problem I ran into. I’m also an automatic and that shouldn’t matter.
    I’m unsure of what the OEM fluid is rated at but to find out just read the bottle, it should tell you.
  15. Apr 18, 2018 at 9:06 AM
    #75
    Derk33
    Derek
    Pennylvania
    Well now I’m at a loss, last night I didn’t grind at all and this morning it is back to the same old awful noise when I shift in 4h
  16. Apr 18, 2018 at 9:47 AM
    #76
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    OP Did you use that additive Gearcruncher linked for you??
  17. Apr 20, 2018 at 3:48 PM
    #77
    Derk33
    Derek
    Pennylvania
    No I never ordered it but today I removed the front drive shaft, jacked the rear end up with the tires spinning and put it into 4wd testing to see if it was infact the Tcase making the noise annnnnnd it wasn’t, I think it’s actually my front end making the noise
  18. Apr 20, 2018 at 6:33 PM
    #78
    Derk33
    Derek
    Pennylvania
    Anyone have any ideas on what it could be?
  19. Jan 30, 2022 at 4:14 PM
    #79
    VikingTrad3r
    VikingTrad3r Well-Known Member
    "contractor model" white with black fenders
    Hey Derk, i see you are still active on this forum. Can you let us know what the fix was? mine has been doing this since 2017, my only solution has been to only shift into 4x4 high when not moving.
    Im quite sure mine is in the front too. I think its a slow weak actuator but i havent found any other posts that have the grind you describe.
    Yeah i know this is an old thread but i see Derk is still active here and it will help others like me.
    Cheers.
  20. Jan 31, 2022 at 5:03 AM
    #80
    Derk33
    Derek
    Pennylvania
    You know I never really did figure it out. I’m almost certain it’s the 2hi 4hi synchronizer inside the transfer case. It still happens when it’s cold out but it seems to be marginally better? I tried putting mt90 in and that seemed to help a bit. Money has been kinda tight for awhile so I haven’t really been able to properly diagnose it. I figure if it blows up then I’ll deal with it lol. Sorry I can’t really help
