Transfer Case Issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikeyD308, May 18, 2014.
  1. May 18, 2014 at 7:27 PM
    MikeyD308
    MikeyD308 [OP] Member
    North Georgia
    '97 White Tacoma 4x4 3.4L
    I have a 97 Tacoma 3.4L 4x4. Manual 5speed, Manual J gate transfer case.Manual Hubs.
    Now heres my issue: My transfer case does not engage the front drive shaft. If I lock my hubs the drive shaft is locked so I know its not the hubs that are the problem. If I select 4lo the transmission goes into low range but still no power to the front. :confused: Any help is appreciated and thanks in advance!
  2. May 18, 2014 at 7:31 PM
    two4spooky
    two4spooky Active Member
    Stuart
    AL
    '97 Tacoma SC 4x4 V6 MT
    LockRight locker, LineX
    Broken chain maybe? Drain the transfer case fluid and try to look inside the drain hole with a pen light.
  3. May 18, 2014 at 8:41 PM
    MikeyD308
    North Georgia
    Ive dropped the tranny and transfer case because I needed to replace the clutch. I took the opportunity to look at the transfer case and removed it from the transmission. I cant see anything blatantly wrong. The chain is intact and spins the front flange. However I cant see what ties the power into the chain. I dont see what connects transfer input shaft to the front output shaft. Am I missing something? I cant find much information on this online.(The vf1a)
  4. May 18, 2014 at 11:07 PM
    gearcruncher
    Canadain bumper technician
    The synchronizer transfers the power from 2hi to 4 hi . When you pull the transfer case lever into the 4wd position , you are also moving the shift fork from 2 hi to 4X4 . The shift fork moves the synchronized hub from 2 hi to 4x4 .
    If you look at this illustration of a basic transfer case . It shows the synchronizer hub # 17 and the fork is # 10
    http://www.justanswer.com/chevy/4gxvr-chevrolet-silverado-1500-hi-i-having-problems.html
  5. May 19, 2014 at 7:09 AM
    MikeyD308
    North Georgia
    I started to examine it a little closer this morning and a roll pin fell out of the bottom of the transfer case. It is smashed pretty bad, so that explains why it came out. Now my question is where did it come from?
  6. May 19, 2014 at 8:56 AM
    gearcruncher
    Roll pins hold the shifter forks in place . How long was the role pin and how wide was it ?
    In that expanded transfer case picture , look at the two shift forks . # 19 and # 17 and you will see the where the roll pin fits through the forks . If one of the roll pins falls out , chances are you will not get 4x4 or 4x4 low depending on what roll pin fell out
  7. May 19, 2014 at 8:58 AM
    gearcruncher
    Thats your problem dude !!!
    Take the transfer case back out and apart . go grab a new roll pin and hammer it in
