Transfer case Issues
Discussion in 'Technical Chat' started by TDOGGY, Apr 7, 2010.
  1. Apr 7, 2010 at 7:11 PM
    TDOGGY
    TDOGGY [OP] Well-Known Member
    Travis
    Salt Lake, Utah
    2005 Tacoma
    Grill color matched, shifter ball, shell, 5100's all the way around.....
    ok so i hit Moab over the weekend. First time out there with my 05 Taco, I ran 4 hi for most the trail and hit some more technical spots that required 4 lo. My truck has 36,000 on it has been very well maintained, fluids and all have been checked and are all in order per the dealer. 4 lo wouldnt engage when i needed it, then when it did it wouldnt disengage for about an hour. That is after all the out of gear, reverse, level ground, shut off, battery disconnect, and all that jazz. Im used to manual 4x4, this sent me into a world of pissed off. So i finally after having a major wigg out just shut the truck down for 5 minutes and bam there she was. The truck was back in 2 wheel drive. What the hell? I got back into town and talked to a auto parts store, they say this is common and that Tacomas with electronic motors have solonoid sticking problems that the motor isnt strong enough to push or release the solonoid and shutting it down to equalize the pressure is the only remedy, minus making a conversion to manual.
    Anyone have this problem any advice, or is my truck on the fritz????? Again Fluids are good, runs fine, no noise, the thing is solid as hell.
  2. Apr 7, 2010 at 7:54 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Yep it's a piece of Shit design, the Stealership service manager even told me with a straight face that having to make multiple attempts to get 4Lo engaged or disengaged is perfectly normal.
    They have worked on mine twice and although it is much better I can't count on it working when I may really need it.
    For 30 years I was a Toyota 4X fan and never had anything but positive comments about them, I convinced a lot of my buddies to get into them but my 08 changed that, Toyota is nothing special too me any longer.
    Sure wish they'd get back too what made them stand out in the offroad world when it came to dependability and reliability.
  3. Apr 7, 2010 at 8:26 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Unfortunately the only solution I think is to use it more. When I bought the truck first time I used had the same problem. Now It is much better but I do use 4x4 more often and use 4L from time to time just to lubricate
  4. Apr 7, 2010 at 8:35 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I refuse to help you out of pure jealousy of you wheeling Moab.:mad:
    just kidding x2 on what ^he said. You seem to know your stuff but I don't want to ASSume.
  5. Apr 7, 2010 at 8:40 PM
    jandrews
    '09 FourDubDee TRD OR
    No problems with mine this first year, and I don't even bother with the 10 miles/month in 4x4. Popped in and out of 4Hi/4Lo with just a little cuddling (the occasional couple feet in reverse) every time I needed it this past winter.
  6. Apr 7, 2010 at 8:49 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    They should have kept the old school version with the manual 2h 4h 4l shifter.
  7. Apr 7, 2010 at 8:50 PM
    Jason'sLawnCare
    ha, i missed that to. It's not too often that there's a manual double cab, I know they are out there I just don't see/hear about them much so apparently I did ASSume and didn't even know it.
  8. Apr 8, 2010 at 8:25 AM
    BlueT
    NorthEast
    Ya but mall crawlers had problems shifting into 4x4 since in left hand they hold iphone, in right hand starbucks coffee which was getting spilled when you pull the lever. Knob you can turn with out removing coffee from your hand ..:p
    Plus soccer moms were confused by two sticks next to their legs :D
  9. Apr 8, 2010 at 8:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    This thread is another argument for First Gen superiority................That is all.
    :p
  10. Apr 8, 2010 at 8:33 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    ^ This.
    The transmission needs to be in neutral, you must be completely stopped, and the clutch must be to the floor to shift in and out of 4x4 low.
  11. Apr 8, 2010 at 8:35 AM
    BlueT
    NorthEast
    Yeah but first gens are getting crushed... and Toyota is making trucks for shopping in walmart.. So either way we are screwed. Only solution is to get 2006-2008 truck with out electronic traction help and putting manual things from Marlin. Thats what my plan is if that transfer case craps on me.
    :p[/quote]
  12. Apr 8, 2010 at 8:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    Excellent plan................I like the way you think.
  13. Apr 8, 2010 at 1:05 PM
    desertdude59
    [/quote]
    I'd love to have a crawler box.:)
    Uh oh 3 shifters total!
    Might have to hire a driver!
  14. Apr 8, 2010 at 2:18 PM
    TDOGGY
    Travis
    Salt Lake, Utah
    2005 Tacoma
    Peddle to the floor dead stopped and in nuetral is the way i rolled it. I did the stop, all of the latter then the reverse, the level ground, the anger of crawling underneath and smacking the transfer, all of it and nothing. it took a shut down 5 minute break with the truck completely off and a restart to get the damn thing to release.
  15. Apr 9, 2010 at 7:34 AM
    98tacoma27
    Ben
    Not Beech Creek
  16. Apr 14, 2010 at 4:33 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Not all Taco's are created equal. My 2009 shifted in and out of 4H and 4L no problem, even when brand new. My 2010 has had issues, (1 - 20 minutes and multiple tries in cold weather). Stealership replace the actuator, and it is still not fixed. Point being, those who comment that theirs works fine, it's not always the operator.
  17. Apr 14, 2010 at 4:40 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Wow Hemi, you're still having issues with the xfer case... Sorry to hear that.
  18. Apr 15, 2010 at 6:19 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    LMAO!!!!!:laugh:
  19. Apr 15, 2010 at 7:39 AM
    BlueT
    NorthEast
    that sound liek it is binding somewhere. Is that only when shifting to 4H or to 4L
    Is it still taking long time to shift...?
  20. Apr 15, 2010 at 7:40 AM
    BlueT
    NorthEast
    Its true :cool:
    Damn I am missing my 99 Taco. :mad:
